Hi
My Salus RT500RF receiver is no longer working. The controller works fine and the boiler is working fine for hot water, however the receiver has no lights.
The receiver is on the same fuse as the boiler and the wiring is secure, it's been working fine for 7+ years but has suddenly stopped.
Is it just time to replace the central heating controls? Or could it be something more simple?
If I do need to replace, will all brands use a similar wiring set-up and therefore an easy like-for-like change?
Central heating receiver not working - Salus RT500RF
- 17247574258462110189162363398490.jpg (141.37 KiB) Viewed 726 times
- 17247573920362400191651387225885.jpg (105.56 KiB) Viewed 726 times
- Has thanked: 47 times
- Been thanked: 2571 times
Have you actually checked for voltage at the receiver?
