uPVC Trim Required
graham101
Has thanked: 90 times
uPVC Trim Required
Post by graham101 »
The edge of our conservatory window shelf is getting messy and grubby, but can't find any suitable trim for the job. Did try sealient but does not last long and gets messy.
The issue is the 10mm x 1mm bit which is part of the window (bottom), this stops all the usual quadrant trim from fitting well.
Any suggestions or link to some suitable trim.
I would cut the shelf corner cover to allow the trim to fit well in the corner.
Cheers,
Graham.
yartin
Has thanked: 145 times
Been thanked: 129 times
uPVC Trim Required
Post by yartin »
Adding UPVc trim is transferring the problem some where else IMO.
graham101
uPVC Trim Required
Post by graham101 »
If the trim is not too expensive then I could replace it when it get bad again.
Currently it's a mess!
Rorschach
Has thanked: 112 times
Been thanked: 1041 times
uPVC Trim Required
Post by Rorschach »
Why is the sealant failing would be my first question.
A decent silicone cleaned regularly should last 10 years or so IME.
yartin
uPVC Trim Required
Post by yartin »
I would clean the area thoroughly, may need silicone remover, wipe with methylated spirit, make sure fully dry then apply silicone with profiling tool and patience. Ct1 and Dow corning are good brands.
These users thanked the author yartin for the post:
graham101 (Mon Sep 23, 2024 4:48 pm)
stevei
Has thanked: 87 times
Been thanked: 123 times
uPVC Trim Required
Post by stevei »
These users thanked the author stevei for the post:
graham101 (Tue Sep 24, 2024 6:57 pm)
Return to “General DIY forum”
