Lifting paint
Piscator
Has thanked: 11 times
Lifting paint
Post by Piscator »
Hi everyone,
I’m hoping some of you guys might be able to help?
I’d put tesa yellow tape around the patio doors before caulking and when I peeled it off the old paint just lifted away!
I’m going to be repainting the room but need to know the best way to repair the damage.
Photos included so you can see what’s happened.
Many thanks 🙏
https://www.dropbox.com/scl/fi/qwrhk9wx ... 4izcl&dl=0
https://www.dropbox.com/scl/fi/78at0yhl ... z3nl6&dl=0
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 569 times
Lifting paint
Post by moderator2 »
Better to attach the pics.
These users thanked the author moderator2 for the post:
Piscator (Wed Oct 02, 2024 7:33 am)
Piscator
Lifting paint
Post by Piscator »
Sorry I couldn’t work out how!😳
Has thanked: 1415 times
Been thanked: 4024 times
Lifting paint
:welcomeuhm: looks like the original paint was missing a mist coat, as a result the top coat/s have not adhered properly. ( A mist coat is a thinned down layer of emulsion applied to bare plaster) Bare plaster is highly absorbent, if you go over with a full undiluted coat the plaster sucks all the water up and leaves a layer of pigment that is easily removed by tape.'
Sand back as best you can, apply a coat of emulsion (TRADE) thinned by 10-20% leave to dry then over paint.
Piscator (Tue Oct 01, 2024 4:49 pm)
Piscator
Lifting paint
Post by Piscator »
Even rubbing down will it not leave an uneven ridge between the existing and the thinned emulsion?
Lifting paint
when sanding feather in the edges, when painting drag the brush back towards you after doing your up/downwards strokes. it shouldn't leave a noticeable ridge.
Piscator
Lifting paint
Post by Piscator »
That’s brilliant thank you for the advice 👍
Piscator
Lifting paint
Post by Piscator »
Just a thought would it be ok to use BIN instead?
Has thanked: 823 times
Been thanked: 3560 times
Lifting paint
I was going to suggest a water based undercoat to seal it. Zinnser Gardz would be better than BIN here.
Piscator
Lifting paint
Post by Piscator »
I’m going to be using Littlegreen intelligent matt, could I use that thinned down?
Lifting paint
I see it that the lifting was caused by the tape. It would indicate that the paint under was not bonded well but that does not mean that if you paint over it will peel off on its own. I was saying a bit of water based underocat like you use for the trim would act as an adhesion promoter but in all probability emulsion will do it alone. I always think that the dried emulsion on a stirring stick seems well bonded. You need to watch changing areas of absorption as you can get ghost marks showing the undercoat.
Piscator (Wed Oct 02, 2024 2:56 pm)
