Looking for this shelf bracket
Ted2
Post by Ted2 »
I'm having trouble finding this sort of shelf bracket. Can anyone point me in the right direction please?
Has thanked: 1414 times
Been thanked: 4019 times
It's called a twin slot bracket one example https://www.toolstation.com/white-twin- ... ing/p20828
Ted2
Post by Ted2 »
I'm familiar with this type of bracket but this particular one is like none I've seen before - look at the lugs.
Ted2 wrote: Wed Oct 23, 2024 5:32 pm like none I've seen before - look at the lugs.
Looks exactly like the ones we used to use in a retail store, probably best to look for industrial/retail brackets.
London mike 61
Has thanked: 285 times
Been thanked: 402 times
Post by London mike 61 »
Try searching with google lens , under the search bar in google there are a few search buttons and one of them is labelled shop with a screenshot.
Take a screenshot and then tap on the button , you will be prompted to load a photo from your photo library, once loaded google will search for that item.
It’s very simple to use .
Mike
Ted2
Post by Ted2 »
I've realised my first picture could be misleading. Here's another from a different angle.
Ted2
Post by Ted2 »
London mike 61 wrote: Thu Oct 24, 2024 7:52 am Try searching with google lens , under the search bar in google there are a few search buttons and one of them is labelled shop with a screenshot.
Thanks for this suggestion - many hits but nothing matching my bracket.
Has thanked: 820 times
Been thanked: 3519 times
The critical thing here is the space between the hooks to marry up with the slots in the existing wall bracket. Buy two or three supports to replace all for that shelf run if you can find some that work. Do a pencil rubbing and have a wander into BnQ and Wickes to see what they have.
Return to “General DIY forum”
