Hi all , looking for some advice pls
Our central heating pump died , the valves were stuck so I drained down the radiator loop and replaced the pump & valves
Everything back together , trouble is now radiators are not playing ball , tepid upstairs , cold downstairs .
Pump is spinning ok , valves are all open ... Bled all radiators was no air in any of them .... I think we might be airlocked somewhere in the system but no idea how to solve it , tried turning the pump on and off a lot but that didn't work
System is confusing to say the least:
Log burner with back boiler (no other boilers)
2 loops from the fire, one for the radiators , one for the hot water , BOTH go through Immersion tank coils
9 radiators
Micro bore pipes sadly (6mm I think)
Any help appreciated !!
Help pls , central heating
- Has thanked: 47 times
- Been thanked: 2590 times
I am NOT a plumber or heating engineer, but is the pump mounted the correct way?
