Cat flap installation
Really looking for feedback from you guys. Recently had these cat flap installed and I have been informed that this would be the standard and then obviously filled with Silicone.
Have a look at the photos and give me your opinion
- 20240306_131545.jpg (164.88 KiB) Viewed 143 times
- 20240306_131541.jpg (170.86 KiB) Viewed 143 times
- Has thanked: 47 times
- Been thanked: 2575 times
It has been mounted on its side and the hole is too big, but that maybe because it is a replacement (Judging by the small round holes.)
- Has thanked: 100 times
- Been thanked: 876 times
Looks like a used cat flap if it was new you would have both inner and outer parts - looks like its also missing its lock too
Installation isn't fantastic, looks like a cheap flap - staywell may some decent ones
Edit. It looks twisted, top left is pinched
- Argyll
- Has thanked: 1180 times
- Been thanked: 580 times
That's as rough as a junkies carpet!
I fitted one a few months ago. As I recall you trace around the cat flap and come in 11mm. That's the roughest job I've seen. They've totally f*ck your door. You'll need to get a proper joiner in to customise some kind of external trim to hide the gap.
Sack who ever fitted that. They haven't a clue what they're doing.
- Has thanked: 818 times
- Been thanked: 3514 times
To remedy this using the cat flap you have it needs to be turned verticle. The gap will need to be adjusted using strip wood https://www.diy.com/departments/smooth- ... lsrc=3p.ds which is not too thick and easily formed to form a subframe to set the flap in. The existing hole may need to be opened up slightly first.
Rotate your monitor/screendewaltdisney wrote: ↑Fri Dec 06, 2024 11:29 am To remedy this using the cat flap you have it needs to be turned verticle. The gap will need to be adjusted using strip wood
Oh yes The strip wood subframe would still work, a bit of paint to make good.
- Bob225 (Sat Dec 07, 2024 12:12 pm)
