3 port zone valve hot
llamedos
Post by llamedos »
My zone valve is hot to touch, it's working correctly when demand is needed for heating and water but motor unit gets so hot and stays hot to touch even when there is no demand and even when heating and water is off at the timer all night, does this mean my motor unit needs to be replaced?
Has thanked: 48 times
Been thanked: 2604 times
I am NOT a plumber or heating engineer, but my guess would be that the motor that turns the valve is still running. I believe it is supposed to stop after it has moved. It may be something as simple as the travelling arm has missed the microswitch that turns off the motor.
Has thanked: 831 times
Been thanked: 3627 times
The valve motors are quite easy to change see this to give you an idea https://www.youtube.com/watch?v=M9DkNwVL4Dc
OnlineOnline
llamedos
Post by llamedos »
Thanks DWD
llamedos
Post by llamedos »
Thanks Someone-Else, will replace head as awkward to see, at least will have a spare.
