Adhesive wet and crumbly (Tiles 'fall' off)
anderino
Post by anderino »
I've clearly done something wrong....
I laid 10 tiles on the wall last week, everything went fine, until I started poking around. I could see if I pressed one slightly it moved so I put a screw driver under one and it popped off with VERY minimal pressure.
When the tiles came off the adhesive stayed on the walls and has been fairly difficult to get off. Its quite crumbly though.
I left them 5 days, should I have left them longer before proding?
I used adhesive from a tub
I want to tile them back on but fear this will happen again!
Many Thanks
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
Are the tiles in a very wet area?
Was the tile adhesive waterproof?
anderino
Post by anderino »
Thanks for your reply.
They are in the bathroom but it hasnt been used as a bathroom properly yet so no water or steam.
Says 'shower proof', the guy in the shop said this is the one to use for the bathroom, its Mepai Mapestik.
Site Admin
I'd try a different adhesive if I was you as it looks like there could be something wrong with the adhesive that you have. Normally they should be well fixed after about 24 hours.
The term showerproof can also be a bit misleading as that does not necessarily mean that it is waterproof.
anderino
Post by anderino »
Thanks, what adhesive do you recommend?
Also the walls are plastered over brick, do you recommend I seal with anything?
Site Admin
What material are the tiles made from?
Site Admin
anderino
Post by anderino »
They are porcelan. I used BAL Flexible Rapidset this morning and just checked now and they arn't going anywhere, thanks for the advice, was losing heart!
:boxing:
Site Admin
Excellent. :thumbright:
BAL adhesives are used by many professional tilers.
Jaeger_S2k
Pro Handyman
Has thanked: 20 times
Been thanked: 27 times
Post by Jaeger_S2k »
anderino wrote: Mepai Mapestik.
It's not suitable for Pocelain tiles, that's why they 'fell' off.
It wasn't the adhesives fault but the application.
You needed Mapei KERAQUICK.
Mapei is also used by professional tilers :wink:
Jaeger.
