Tile drills seem so be expensive for what they are. Are most tile drills similar in make, or is there a massive difference between different brands?
I have seen some Armeg ones and they were mega expensive
Tile drills
For tile drills you can't beat these prices-
http://www.richontools.com/
They sell these bits-
http://www.ultimatehandyman.co.uk/tilin ... l_bits.htm
and standard tile drilling bits-
http://www.ultimatehandyman.co.uk/tilin ... _tiles.htm
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
I have never bought a tile drill yet and never broken a tile drilling them I use a normal masonary drill and masking tape,just tape the area you want to drill start the drill slowly until you get through the glaze then you can up the speed to drill the hole
you watch next time a drill a tile
For a cheap tile drill bit set I'd recommend 365 Drills. Its not gonna last more than 1 job but it gets through porcelain ok and only cost about £40 quid from here - http://*Alert moderator- please report this post*/. You dont need expensive arbours either the kit comes with a drill plate
- EJJ150847
- Has thanked: 35 times
- Been thanked: 188 times
I'm with cannyfixit, until I won a set of diamond hoelsaws on UHM, I've always managed using ordinary masonary drills, slow speed, sometimes a pool of water, using slow speed. After drilling the hole, always use a slightly bigger size to 'counterbore' the tile so the plug sits beneath the top of the tile.
John
John
