Ive just watched this beast in action......It was quite noisy but did the job of cutting out the old grout in a shower. Pity was the user must have slipped cos there is a chunk and a scrape missing from my wood ceiling now! So just watch whose hands it gets into!!! If their fingers are too big for bowling bowls and they have a passion for women who look like men, then be cautious if they have this in their hands, they could damage your ceiling too!
I wish I'd had mine when I did my kitchen, I had to put a false wall in and move sockets would've been handy then.
I'll have to think of a use for it before SWMBO finds I have'nt used it!
Def concrete - the house was built about 1950 when there wasn't a lot of wood. Even the joists are mostly concrete with a small wooden center to nail the floor boards in.
I bought a 180E today from my local B&Q for £60. Cut through plasterboard no problem at all. Not so great with 15mm copper pipe as the edge was a bit ragged but that was probably down to me rather than the Bosch.
I sanded a varnished window frame back to the wood and was amazed; my B&D mouse is nowhere near as good! The only problem is, the sanding pad seems to have melted at the corners...
Repo wrote:Def concrete - the house was built about 1950 when there wasn't a lot of wood. Even the joists are mostly concrete with a small wooden center to nail the floor boards in.
It is awesome at sanding!
I struggled cutting the copper pipe, although when I needed to use it on a piece that was wedged between two joists it was the only thing I could use.
I just bought one! Looking forward to having a go at diy using it. It was just under £60 but because I bought 3 de-icers for the price of 2 and spent £60,63p I got a £5 gift card for B & Q too.
I was wondering whether there is anything else that I should have bought to use on it. Are the attachments in the case really all you need?
Failure means you just didn't get it right yet!
Louise
