It's Arrived!
chat_to_rich
Been thanked: 45 times
Re: It's Arrived!
Post by chat_to_rich »
Please could you post a screen shot. I'm not at my machine that has the RAID array at the moment, so this is all from memory.
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Re: It's Arrived!
Post by thescruff »
An initialize disk box has drop down
Do I want MBR or GPT
thats master boot record or guid partition table
chat_to_rich
Re: It's Arrived!
GPT
chat_to_rich
Re: It's Arrived!
FYI GPT supports volumes over 2TB, so is worth having for future expansion etc.
chat_to_rich
Re: It's Arrived!
When you create the partion choose quick format. Label the drive as RAID or something obvious.
thescruff
Re: It's Arrived!
Post by thescruff »
Did that and pressed ok.
Now got system 0 ---system reserved.
Disk 1
thescruff
Re: It's Arrived!
Post by thescruff »
Where/how do I partition the disk
chat_to_rich
Re: It's Arrived!
You should see a black bar for the new drive. Right click and choose new simple volume. Go through the wizard, assign a drive letter and quick format. We may need to finish this tomorrow. Hope that's ok.
chat_to_rich
Re: It's Arrived!
Just to be clear, the above instructions are still within Disk Management.
thescruff
Re: It's Arrived!
Post by thescruff »
You can finish tomorrow if you wish.
Called itself drive D,
New volume (D) is now showing in the top below C
thescruff
Re: It's Arrived!
Post by thescruff »
chat_to_rich wrote:Just to be clear, the above instructions are still within Disk Management.
No good telling me after I done it :lol:
Drive D say Healthy (primary Partition)
chat_to_rich
Re: It's Arrived!
Sounds like it's all done - well done!
If you look in Computer you should now see D, which is your RAID drive. Tomorrow I'll post a screenshot for you to compare against so we can be sure it's all setup correctly. Then we can plugin your spare disk and start moving over your files.
These users thanked the author chat_to_rich for the post:
thescruff
thescruff
Re: It's Arrived!
Post by thescruff »
Got a drop down box to say view files in windows explorer. and it shows as new volume 1.81TB :thumbright:
I assume I can close all the open bits now.
thescruff
Re: It's Arrived!
Post by thescruff »
This post is on the new computer so it still works. :roll:
Thanks again Rich.
See you some when tomorrow :thumbright:
chat_to_rich
Re: It's Arrived!
Please can you post a screenshot of the Intel Matrix Storage Manager, like the one I've attached to this post. Please can you also post a screenshot of the drives that are visible when you click Start -> Computer. I want to check that everything's setup correctly before we continue.
Return to “Computers”
