When you dig it over it will be lumpy with dead stuff in. Leave it a day and it will have dried a bit so it will break up easier. Add a bit of compost at this point mix it all together and rake it smooth but loose. Next, I used a hand fork and ploughed some furrows systematically and sprinkled seed in before brushing the soil back over. This gives a constant pattern when it grows rather than scattering and hoping for the best. I still had a few bits I had to resow. You do not want it to look like Rooney's bonce.
What you could do is after you have raked it in and watered it put a couple of black bags over it, that will keep it moist and it will come up in a week, then take the plastic off.
Whatever you have will be good. I have never tried forcing under plastic like Adonis mentions above so I cannot comment on that bit. this will be a bit of a slog but do it in stages if you get tired. There is no hurry.
Hello again!
The grass seed seems to be growing well now , only problem is there is a lot of patchy areas. My thinking is to cut the grass then add some more seed and soil - does sound like the right thing to do?
Thanks!
Thank you! I put the grass seed down nearly 3 weeks ago, should I be able to cut it now or hold off a bit longer?
I’m definitely going to pay a lot more attention it it from now as it was a bit neglected
That looks good. You can cut but adust the mower to a high cut just to level it out a bit. The bare areas you need to do with a small hand fork. Plough some furrows and drop the seed in before covering over. I have done exactly that on mine and it is all a solid lush patch now. How did the steps go?
Woohoo! Just need to wait for the rain to have a break and can get it cut!
The stairs are back to normal now and can walk up them without the worry of them collapsing we rarely use them but nice for them to be fixed for when we need to! You’ve been a great help!
