Drilling thick cast iron plate
Distorted Vision
Has thanked: 4 times
Been thanked: 7 times
Post by Distorted Vision »
Done. Couldn't believe that the holes lined up perfectly first time as marking them wasn't easy. Biggest challenge was clamping the cast iron plate to the table of the drill as I was drilling the top surface so it was resting on the socket for the post.
The drill itself is excellent and I'm really happy with it. Couldn't believe how accurate the laser was and how it went through the cast iron like a hot knife through butter.
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
Good job.
As an aside, you can get "transfer punches" for either plain or threaded holes
https://www.arceurotrade.co.uk/Catalogu ... Punch-Sets
https://www.arceurotrade.co.uk/Catalogu ... fer-Screws
Makes the job easier, but probably too expensive for a "one off"
Might help somebody else though.
bourbon
Has thanked: 11 times
Been thanked: 19 times
Post by bourbon »
Grendel wrote: Wed Oct 13, 2021 5:16 pm Yes a Jack would work , or even for that matter a length of timber propping it up. Saying that , if you were to see his workshop finding the floor under the drill to stand said jack on would be another issue...😊😊
I have since tidied up (a bit)
Return to “Tool Talk”
