Getting an EIC certificate
rapidnailer07
Has thanked: 35 times
Been thanked: 3 times
Post by rapidnailer07 »
Wow...so much confusion. I assume in current age, an EIC certificate is just a PDF document so not sure why there's so much hassle to forward a copy to me even if it's not normally required. Yes, I will be eventually getting a building completion certificate but no harm in me getting the EIC certificate as well. I believe it has some technical information on their such as the quality of the wiring which can then be used to compare against future EICR reports, right? If the Building Regs completion certificate doesn't contain the same level of information then there is benefit in getting the EIC report directly from the electrician too.
I'll speak to the electrician again and ask nicely if he can forward me a copy whether he thinks I need one or not.
Neelix
Has thanked: 118 times
Been thanked: 219 times
Post by Neelix »
rapidnailer07 wrote: Fri Oct 15, 2021 9:51 am Wow...so much confusion. I assume in current age, an EIC certificate is just a PDF document so not sure why there's so much hassle to forward a copy to me even if it's not normally required. Yes, I will be eventually getting a building completion certificate but no harm in me getting the EIC certificate as well. I believe it has some technical information on their such as the quality of the wiring which can then be used to compare against future EICR reports, right? If the Building Regs completion certificate doesn't contain the same level of information then there is benefit in getting the EIC report directly from the electrician too.
If you read the photo above it states that you the home owner should be given a copy by the spark
I do agree this is a mess but that’s the way I have always done it
These users thanked the author Neelix for the post:
rapidnailer07 (Fri Oct 15, 2021 10:03 am)
ericmark
Been thanked: 785 times
Post by ericmark »
I would agree you should provide owner with an EIC, but there is no law to say you must, remember BS7671 is not law.
So a non scheme member in England have two legal routes for notifiable work. A scheme member who has the authority to inspect and test third party work (Not permitted in Wales) or the LABC, if using the latter which is likely only way as most the scheme providers will not authorise third part testing and inspecting, either way the inspector can't issue an EIC as he has not done the work, the normal is to use an EICR form which is nearly the same as an EIC form, but this does NOT need to be passed to the owner, it is only given to the LABC and all the owner gets is a completion certificate.
Yes I see there is a problem as new landlord law says
obtain a report from the person conducting that inspection and test, which gives the results of the inspection and test and the date of the next inspection and test;
and the completion certificate does not give results, so a completion certificate is not enough, you would need an EICR doing if renting the property.
n installer who is competent to carry out inspection and testing should give the appropriate BS 7671 certificate to the building control body, who will then take the certificate and the installer’s qualifications into account in deciding what further action, if any, it needs to take. Building control bodies may ask installers for evidence of their qualifications.
So only when the installer is incompetent will the EIC not be completed, however I know when I did work in Wales I had problems getting the LABC to accept my qualifications, if the LABC does not accept the qualifications then the EIC will not be valid even if issued as the completion certificate is not issued using them.
My mother had some work done by social services in Wales, it was to mains power the door bell/intercom and they engaged an electrical firm to do the work. It involved fitting a new socket, and plugging in a wallmart unit to provide 12 volt DC to the door bell unit. The socket was next to consumer unit, and clearly a new circuit, and when complete I inspected it, and felt it was poor workmanship, so plugged in the RCD tester and realised the RCD did not trip.
At that time it was permissible to have a non protected socket if it was labelled as for some thing special, like a freezer, but no label on the socket, so I contacted social services asking for the minor works certificate, and they told me to contact the electrical firm direct, it was clear the socket had been connected to wrong side of CU, however a simply label would have resulted in it complying, however I could not get the minor works and in the end gave up. House was latter rewired.
However if the county council can't provide the owner with a minor works certificate or completion/compliance certificate, what chance is there of them forcing some one else to provide one?
rapidnailer07
With regards to the Part P certificate, I'm confused with that and the various responses mentioned. Given I'll be getting a Building Reg Completion certificate, does this mean I should still ensure I get a Part P certificate? Or does the BR Completion certificate supersede this?
Neelix
Post by Neelix »
rapidnailer07 wrote: Mon Oct 18, 2021 10:44 am With regards to the Part P certificate, I'm confused with that and the various responses mentioned. Given I'll be getting a Building Reg Completion certificate, does this mean I should still ensure I get a Part P certificate? Or does the BR Completion certificate supersede this?
Interesting question which I’m not sure of the answer
But given you said earlier the spark you used is a CPS member push them for the part P and the EIC
ericmark
Post by ericmark »
Neelix wrote: Mon Oct 18, 2021 11:15 am But given you said earlier the spark you used is a CPS member push them for the part P and the EIC
I think people call it a Part P certificate because there are two names for basic same thing, if issued by LABC it's called a completion certificate, and if issued by a scheme provider a compliance certificate. But as far as aware there is no such thing as a part p certificate.
The problem is it seems there is a tick on the paperwork when applying to the LABC to say if they are inspecting the electrics or if a scheme member is doing the inspection. And I have seen it where LABC thought a scheme member was doing it, and an electrician thought the LABC was doing it.
These forms Image are sold by electrical outlets for "These certificates are for use by electrical contractors not enrolled or registered with NICEIC or Elecsa and for Approved Contractors working outside of their scope of enrolment." but they have NICEIC and Elecsa written on the certificate which is misleading, and people think they are employing a scheme member and they are not.
Also in England the restriction as to what needs notifying was reduced, and many electricians have considered not worth paying the NICEIC or Elecsa for membership, but have not as yet had the logos removed from their vans or paperwork, however the rules are, if the electrician says he is a member on anything, then he must be a member, and he is responsible for the compliance certificate, if he does not say he is a member then the home owner needs to have right box ticked on the LABC application and the completion certificate is all that is required.
However often the LABC will not issue the completion certificate without the compliance certificate if wrong box ticked.
There is no legal requirement for an EIC, regulations do say they should be issued, but the regulations are not law.
Return to “Electric Forum UK”
