What Hacksaw Should I Get?
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
If the slots for the blades are out of line and the lugs are fixed, then there's not much you can do without the job being more trouble than it's worth. Get a new hacksaw of your preferred pattern. One to take 300 mm blades. Get a decent make if you can afford it. For occasional use it'll last a lifetime. Also get some spare blades. High Speed Steel, 18 and 24 tpi. Again get a recognised make.
A junior hacksaw and a pack of blades is useful as well.
When cutting, then as with any saw, cut with steady, full strokes, and don't press down on the blade more than is needed to keep it in the cut. "Let the saw do the work"
I haven't seen one of those double sided blades for years. I think I've got one somewhere. They seems to be carbon steel, and don't last well.
These users thanked the author Dave54 for the post:
ugoleaf (Mon Nov 29, 2021 9:51 am)
ugoleaf
Has thanked: 120 times
Been thanked: 4 times
Post by ugoleaf »
Dave54 wrote: Sun Nov 28, 2021 12:22 pm A junior hacksaw and a pack of blades is useful as well.
Junior hacksaw like those that I posted on picture in the beginning of this thread?
Has thanked: 829 times
Been thanked: 3604 times
Putting blades in a junior hacksaw bent wire rod version requires three hands. You have to compress the bow with one hand and fiddle the blade keeps into the notches. Unless you have vice-like strength it is a real pain to fix them in and a third hand would be useful. Perhaps I am getting weak.
ugoleaf (Tue Nov 30, 2021 3:10 pm)
OnlineOnline
Dave54
Post by Dave54 »
ugoleaf wrote: Mon Nov 29, 2021 9:53 am
Yes, but get one for cutting metal. They appear to be for woodworking, and might have a different blade fixing.
This is the sort of thing I'd get
https://www.toolstation.com/minotaur-ju ... hstr=junio
I prefer that type to the wire type. Easier blade change as Walt says.
Mate of mine gave himself a really nasty cut that needed stitches changing the blade on a wire one.
ugoleaf (Tue Nov 30, 2021 3:09 pm)
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Post by London mike 61 »
Time for a new saw…and blade
Mike
These users thanked the author London mike 61 for the post:
Grendel
Has thanked: 201 times
Been thanked: 515 times
Post by Grendel »
dewaltdisney wrote: Mon Nov 29, 2021 12:12 pm Putting blades in a junior hacksaw bent wire rod version requires three hands. You have to compress the bow with one hand and fiddle the blade keeps into the notches. Unless you have vice-like strength it is a real pain to fix them in and a third hand would be useful. Perhaps I am getting weak.
I tend to push the saw between my belt buckle and something solid which seems to work although saying that i tend to stick with the larger saw as it's easier to change blades.
ugoleaf
Post by ugoleaf »
Dave54, dewaltdisney, London mike 61, Grendel Hello. I bought junior hacksaw made of aluminum but it's a bit bent I think. Will do okay for home DIY?
Nos
Has thanked: 3 times
Been thanked: 80 times
Post by Nos »
For a full size one, see if you can get one with a quick release, saves a lot of time twiddling knobs etc.
These users thanked the author Nos for the post:
ugoleaf (Fri Dec 03, 2021 10:29 am)
Grendel
Post by Grendel »
There does look to be a slight bend on it but i doubt it will cause any problem and should suffice for what you want. In my workshop i've got four large hacksaws plus another couple or so in the garage and van. Most are of the wing nut type . At least one seems to have lost it's tension to a degree but having the wing nut has allowed me to space it with a few washers.
These users thanked the author Grendel for the post (total 2):
ugoleaf (Fri Dec 03, 2021 10:29 am) • Dave54 (Fri Dec 03, 2021 11:30 am)
Rating: 14.29%
ugoleaf
Post by ugoleaf »
Nos wrote: Fri Dec 03, 2021 7:25 am For a full size one, see if you can get one with a quick release, saves a lot of time twiddling knobs etc.
Like this one? That one looks beasty:
https://m.youtube.com/watch?t=150&v=cwwPFyavvCE
These users thanked the author ugoleaf for the post:
Grendel (Fri Dec 03, 2021 12:00 pm)
Grendel
Post by Grendel »
That looks an interesting tool , not one i've seen ( but then already havng half a dozen why would i be looking anyway). I do like the feature that allows the front part to come off and for both parts to be used as seperate saw handles.. Having an option of a hacksaw blade with a handle at just one end is very useful for carefully taking things apart by sawing through fixings . Best to reverse the blade though so it cuts on the pull stroke.
Nos
Post by Nos »
Yes, but that's a different brand, here in France we have a brand called "McKenzie" its similar to the DeWalt but the tensioner is the actual handle.
Return to “Tool Talk”
