How to Remove Rust Faster?
- ugoleaf
- Has thanked: 120 times
- Been thanked: 4 times
Rorschach A lot of dark matter came off, leaving stains. Should I dry and use sandpaper again or straight into bicarbonate soda it goes?
- 20211206_170442.jpg (168.24 KiB) Viewed 3604 times
- Has thanked: 112 times
- Been thanked: 1041 times
Those dark stains are the rust that has been converted by the treatment. A quick rinse with bicarb and then a good scrub with WD40 (scouring pad ideally) should clean it up nicely.
No, a minute or two will be plenty.
- ugoleaf
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2591 times
Believe it or not you can also get "wet and Dry" sandpaper.
- ugoleaf
I guess I can always put paper under tap water and dry it but I thought there's a special kind of paper...Someone-Else wrote: ↑Wed Dec 08, 2021 12:30 pm Believe it or not you can also get "wet and Dry" sandpaper.
- ugoleaf
Rorschach After two cycles of overnight citric acid and baking soda finale I think it will take a few weeks to bring USSR ruler back and make it great again using 800 grit sandpaper. Unless I want to go that route maybe I should use a fine file tool to speed things up? Although a nice polished ruler would be something Golumn would buy.
- 20211210_172534.jpg (172.6 KiB) Viewed 3521 times
- 20211206_170442.jpg (168.24 KiB) Viewed 3521 times
- Someone-Else
............all the TIME and effort, you can buy a new one for £11
- ugoleaf
You will never find USSR made stainless steel ruler.Someone-Else wrote: ↑Fri Dec 10, 2021 4:22 pm ............all the TIME and effort, you can buy a new one for £11
- Someone-Else
Yes I will, there is a set of 3 on ebay
- ugoleaf
I can't believe this... I have failed my mission... All was in vain...
