Best type of ventilation for my property - and costs
Zudecke
Has thanked: 28 times
Post by Zudecke »
big-all wrote: Sat May 06, 2023 1:25 pm what are the problems you are trying to solve ???
is it damp??
is it stale air ??
or somthing else
Condensation...
Neelix
Has thanked: 118 times
Been thanked: 215 times
Post by Neelix »
big-all wrote: Sat May 06, 2023 1:09 pm ventilation is a very subjective thing
a house can have zero provisions for ventilation and the normal use will provide enough air movement to stop excess moisture and stale air being a problem
all you need do is tackle any problems as passively as possible
excessive ventilation can mean extra energy usage in heating and ventilation
Not sure I agree with that. Humans loose moisture, boiling food , drying washing and showers are all together a different matter.
Has thanked: 47 times
Been thanked: 2591 times
I agree with Neelix
Humans give out moisture in the breath, not to mention cooking washing and drying.
Working ventilation is a must.
Has thanked: 736 times
Been thanked: 2342 times
with condensation, you need to reduce the cause first then deal with what's left
things like drying clothes indoors showering bathing and cooking without area relevant extraction will aggravate the situation
its often a Ballance between heat and ventilation, as in heat the space to suspend the moisture in the air before active removal via fan or dehumidifier or an open window
is it a specific room or area that's the problem ??
Neelix
Post by Neelix »
Zudecke wrote: Sat May 06, 2023 1:12 pm
As I mentioned though, we do have a problem with excessive condensation. We've been told airflor is a problem, but don't have anything scientific to share.
I'm told all property's need at least some ventilation. We have none..
Do you have showers?
How do you dry your clothes?
Do you boil a lot of your food?
At the end of the day all these PLUS humans mean moisture in the air so ventilation is essential. Best from one side of a property to the other ...............
I've seen so may rentals with exactly the same issues and all they need is ventilation to reduce the moisture in the air ......
Government advice to prevent drafts has made the problem worse IMHO
