SDS and SDS Plus Drill Bit Compatibilty
Has thanked: 807 times
Been thanked: 3498 times
Also there is a grease port that you unscrew allowing you to finger grease into the gearbox. It is advisable to keep an eye on that too.
Rorschach
Has thanked: 108 times
Been thanked: 1038 times
Post by Rorschach »
dewaltdisney wrote: Sat Jun 17, 2023 10:28 am Also there is a grease port that you unscrew allowing you to finger grease into the gearbox. It is advisable to keep an eye on that too.
Is that on the Titan? I don't know if mine has access to the gears for greasing, will have to look.
Yes, check it out R, I think the access varies from drill to drill. Some have four screws to remove an access plate and you make sure the gearbox is well-packed with Lithium grease.
Rorschach (Wed Jun 21, 2023 8:36 am)
Although this thread is probably resolved I thought I would mention that my cheap SDS bits were Workzone from Aldi as I had them out today. I could not be arsed to get my SDS out and I clamped the bit shank in my cordless and it did the job I wanted. So it is fair to say that you can use SDS+ bits in a cordless if needed.
Return to “Tool Talk”
