Just great 🧐
- Has thanked: 107 times
- Been thanked: 1038 times
Just great 🧐
These days the "unknown" tip about sticking a stanley blade in there is all over the internet even though that tips has been around probably as long as the tool itself. I've been doing it for years mostly with a carpet hook type blade, there is no faster and easier way to cut up old carpets, mats, rubber mats etc. Also good for cutting thin plastics.
Also use mine for general stuff like floorboards and awkward trim cuts.
I have found it very handy in the past for cutting access panels in the side/back of kitchen cabinets, if you are careful you can use the cut out piece with a couple of brackets or a hinge to make the cover.
Be careful if doing this around water pipes though, a quick bump with the blade is enough to put a pinhole in a copper pipe, ask me how I know!
- Has thanked: 32 times
- Been thanked: 805 times
Just great 🧐
so ive got a young apprentice. ive shown him both to chop hinges in with a chisel and also to use a router and a jig.
some kid that goes to colledge apparently told him who uses a router.... thats a waste of time just use a multi tool.
god knows whos teaching the lad if he says that mind
i guess as said i can see it pottentially being of use to some to rough out and neaten up with a chisel though.
Just great 🧐
Depends on the clamping mechanism, usually you need to put a washer or two in there (I do on mine) but then you just clamp it , works great.
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2556 times
Just great 🧐
Yes, me too. One of the first things I realised I could do with a multi-tool. Do bear in mind I have had it for a while, but don't use it much.
- Someone-Else
Just great 🧐
Since I started the thread, are there any particular blades you (anyone) would suggest for cutting metal? TBH (sorry to admit it) I did not know it can cut metal By metal I am meaning nails that are in the way, unless it can cut metal? Please enlighten me, what have you intentionally cut?
- Has thanked: 807 times
- Been thanked: 3496 times
Just great 🧐
I thought that my MT was a bit useless cutting metal. I use a thin cutting disc in my angle grinder for nails, rust frozen nuts, and nails with a quicker, cleaner cut. I found that the MT was slow to cut through metal and the blades dulled quickly. MT 's have their uses but metal cutting is not one of them in my opinion.
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2333 times
Just great 🧐
metal blades dont work well because off the small stroke perhaps 3-5mm so on things like nails they try and jump off sideways or get bogged down and form a "V" between 2 now blunt teeth
this is ok for old nails as they are beaten to death in the "V" but new or hardened screws or nails the blade tends to loose
as said above keep moving the blade and adjusting the angle off attack also try reducing the speed to put it out off sink with the workpiece oscillations
and saxton blades here without even thinking
- Has thanked: 1 time
Just great 🧐
They're like the Swiss Army knives of the tool world. I've used mine for all sorts of odd jobs around the house. One time, I had to trim some overgrown branches on a tree, and my multi tool came to the rescue. It's so versatile and handy to have.
- Someone-Else
Just great 🧐
paul8685, do try and keep up, that conversation finished 4 days after I started it, which was almost 2 months ago.
Just great 🧐
Just to add, I saw someone using one to vibrate a concrete mould for slabs he was making. It worked quite well as I recall.
