Can’t repressurise boiler (low mains pressure)
etaf
Has thanked: 38 times
Been thanked: 151 times
Post by etaf »
Just had this text tho:
Good morning, it's Connor from United Utilities. Just to let you know, we've found the cause of poor pressure in your area to be a technical fault on ourwater network. We're onsite and ready to begin the repairs. Sorry for any inconvenience, we'll have things back to normal as quickly as possible.
How bad is the pressure from the network, and maybe it changed and increased and allowed the 1.5bar change and then dropped again
Simple DIYer
Wayne
and_the_noobie
Has thanked: 9 times
Post by and_the_noobie »
etaf wrote: Sat Dec 30, 2023 11:50 am
toying with that as feasible… currently awaiting delivery of a pressure gauge (due today) that will hopefully take away some of the guessing!
and_the_noobie
So whilst waiting on my pressure gauge delivery (cmon Mr.Amazon man!), the plumber popped by an hour ago with his. We are getting 1 bar downstairs (he put his finger over the tap to prove it), so by the time it is getting upstairs, we’re onto a loser.
Meanwhile, United Utilities text me this morning saying there was a new problem in the area. I’ve spoken to them and they will investigate tomorrow. In the meantime, I’ve checked their website and it says the issue has been fixed in the last hour, so about to try again because the pressure looks better (or is it in my head now… I tried to put my finger over the tap and got soaked 🤣) 😬
Has thanked: 820 times
Been thanked: 3519 times
Did you bleed the radiators? This might be the issue, start upstairs and systematically bleed the radiators with the fill valve open. Take some kitchen roll to catch the weep when it comes.
and_the_noobie
dewaltdisney wrote: Sat Dec 30, 2023 4:40 pm Did you bleed the radiators? This might be the issue, start upstairs and systematically bleed the radiators with the fill valve open. Take some kitchen roll to catch the weep when it comes.
Yeah - tried that and made no difference unfortunately. Thanks tho
and_the_noobie
Curses!
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
See if your gas guy can pop back in.
He needs to depressurise the expansion vessel then fully fill the system leaving it on 0.3 bar or so.
Then if he pumps up the expansion vessel you will have full pressure.
BTW when the water properly goes back on you need to run the cold tap on it's own for 20 mins or so just in case there's any debris in the pipework. You really don't need anything being pulled in to the boiler
and_the_noobie
So this morning, the water pressure has finally been fixed! Not happy with United Utilities, and haven’t felt like I’ve achieved a lot over the past few days (couldn’t get the boiler working) but I did learn a fair bit. So thanks all.
My plan if it wasn’t sorted today, was to get a water pressure test pump to try and force the water into the system (a bit like this https://www.amazon.co.uk/318927-Install ... 00KBQPMII/ ) but I hadn’t fully thought it thru (and didn’t even know if it would work!)
We’ve gone from 0.7 bar at the boiler to approx 2 bar tho so all is good.
Thanks again 🙂
Glad you got it sorted, Connor the autobot was useless :lol:
