Water under wooden floor
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
If it's lead pipe it's a good idea to get shot of it.
bennett
More advice please
Post by bennett »
We are having the same problem but have ruled the drain pipe and all other leaking pipes out.
We have dug a hole in the garden and found water at the same level as under the floor boards.
So now we know it is ground water......and we have a 1meter gap between the floor and the ground.
What would you advise now?
