Save you reading all the old posts, basically I have two lights (top and bottom of stairs) which are operated by two swtiches (top and bottom of stairs). You can't operate either independantly with these swtiches - they are either both on or both off. These two swtiches, instead of having three core wire, have two lots of 2 core with the un-needed wire snipped short.
All sounds fine so far (I hope). However, there is a third light switch which doesn't seem to fit in with the others. I've blanked it off now but from what I remember it only turned one on or when it was on, the others didn't work, or something stupid like that.
Anyway, attached below is my beautiful attempt to show the wiring of the ceiling rose for the one light which has this third switch wired to it.
Told you it was beautiful!
Question:
1) Can I simply remove the switch which I've labelled "funny switch" in the diagram? If I take it out, are lights not going to work or something?
Sorry the diagram is not the best. Any help would be much appreciated, because I don't want to hide the switch somewhere for someone else to ponder over!
