build a shed from sleepers
jonny18
Post by jonny18 »
big-all wrote:my bwain hurts :? :? :? :? :? :? :?
2 walls 7m + 2 walls 3.5 = 21m!!!!! :scratch: :scratch:
no mate, 1 wall at 7 2 sides at 3.5 and the back is a solid breeze, rendered wall.
Has thanked: 736 times
Been thanked: 2341 times
cheers i understand now
when i built my shed more than half the £700 wood costs where the roof and floor but i did use 18mm ply l o l
the sides where 5"tounge and groove shiplap pressure treated
its a 10x12ft shed which incidently =13.2m very close to your 14m the txg cost around £250
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Actually there's no reason why you couldn't clad it with t&g
jonny18
Post by jonny18 »
good photos man.
Tryanything
Been thanked: 4 times
Post by Tryanything »
Suggestion for corners and any internal walls
Sleepers will probably be waterproof already but a coat of old engine oil
and cresote mix would'nt go amiss
Nice big mastic joint between each sleeper and joints and all tosh nailed
together from inside
shed walls.jpg (13.57 KiB) Viewed 2146 times
There would be less trouble in the world
if l had not had six daughters
jonny18
Post by jonny18 »
Tryanything wrote:Suggestion for corners and any internal walls
thanks, will the engine oil or cresote smell permenantly or just while it drys, and what are tosh nails..
do you have a program for drawings like that. i could do with a good program to design work projects for customers.
thanks
jonny18
Post by jonny18 »
thescruff wrote:Actually there's no reason why you couldn't clad it with t&g
any suggestions of how much i should be paying for t&g, or do you know any online sites with good prices. i live in doncaster.
thanks
Tryanything
Tosh nailed :lol:
Any type of nail just toshed in at an angle
The sleepers are going to stink anyway, but after a good summer (ha ha) they should be fine
The program l use mostly is "Draw" in MS Works
Stella
Has thanked: 3 times
Post by Stella »
I just googled for tosh nailed and this post came up in number two position :lol:
