Decking
dirtydeeds
Craftsman Carpenter
Been thanked: 1 time
Post by dirtydeeds »
Earlier i suggested the use of a router to roundover the endgrain of the cut board ends.
Having slept on it i withdraw this suggestion completly as it involves using the router in an unusual manner that is NOT RECOMMENDED in any safety manual.
SAFE METHODS to chamfer or roundover the cut edges of the endgrain include a block plane or a sander.
panlid
Post by panlid »
meanwhile in the real world get the router out :lol:
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
What size spacing would you recommend between the deck boards?
I was thinking of using some small angle brackets to fasten the boards to the joists rather than screwing through them, something like this but galvanised-
owen
Post by owen »
ultimatehandyman wrote:What size spacing would you recommend between the deck boards?
UHM you have too much time on your hands if you can be arsed using those brackets for putting deck boards down! ;-)
You can get purpose made clips for fixing boards with no visible surface fixings, i have not used them so don't know if they are any good.
I allow about 4-5mm between boards, i usually knock a big nail through a piece of wood and use the nail as a spacer.
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Post by Gadget »
Yup, thats what I use, a 4" nail!!
By eck! ©
wood4fun
Has thanked: 2 times
Post by wood4fun »
i use these to fit deck boards Image
wood4fun wrote:i use these to fit deck boards Image
Are the decking boards grooved, or do you have to knock them in?
Do these leave a set gap between the boards?
wood4fun
Post by wood4fun »
you knock them into the edge of the board and fix them to the joist. they will give you a perfect and even gap between the boards. plus no damage to the surface of the boards.
wood4fun
Post by wood4fun »
they come with a fixing tool included and nails to fit them
Niceone :thumbright:
I have been around to my friends today and measured up and it is almost 40 square metres!
There is concrete covered tarmac just 6 inch below the DPC and so it looks like we are going to have to dig this out to be able to get the joists in and the air gap etc.
If I set the joists at 400mm centres would I have to put noggins every 400mm as well?
chez
Gadget
Jack Of All Trades
Post by Gadget »
I did some decking at the back of my house last year, and I spaced the joists at 600mm, and because the deck boards are 30mm thick there is virtually no 'spring' in the boards
By eck! ©
Gadget
Jack Of All Trades
Post by Gadget »
The afforementioned decking
DSCF0250 (Small) (WinCE).JPG (21.61 KiB) Viewed 3707 times
By eck! ©
wood4fun
Post by wood4fun »
looks very nice :thumbright:
the tree growing in the deck what type is it? just because on growth and roots
Gadget
Jack Of All Trades
Post by Gadget »
It's an apple tree, I didn't have the heart to chop it down, but if it becomes a problem I will, and there are 2 apple trees there. If you look to the left and down a bit you can just see the corner of the section I left out for it!.......total size of the decking is 4m x 7.5m.
By eck! ©
