Hi big all thanks for the offer,but will it drill a 32mm hole in wood using a spade bit if you needed to do so cheers.big-all wrote:dont know but my expectaion would be in excess off 40 or 50diyguys wrote:How many 60mm screws could you drive before it went flat no pilot holes?
if its important i will try it out for you
Bosch 10.8v li-2 mini drill £109 @ tooled up
- Has thanked: 178 times
- Been thanked: 19 times
Re: Bosch 10.8v li-2 mini drill £109 @ tooled up
- Has thanked: 35 times
- Been thanked: 257 times
tbh i would not try that with a 18v drill, id have it chucked up in 24v sds or mains sdsdiyguys wrote:Hi big all thanks for the offer,but will it drill a 32mm hole in wood using a spade bit if you needed to do so cheers.big-all wrote:dont know but my expectaion would be in excess off 40 or 50diyguys wrote:How many 60mm screws could you drive before it went flat no pilot holes?
- Has thanked: 25 times
- Been thanked: 116 times
I like the vid, looks quite good to me.
Not sure about drilling into brick though. I've never done that without hammer action, maybe the multi construction bits are better than masonary bits for this though.
I am not a pro.
- Has thanked: 7 times
- Been thanked: 21 times
Inappropriate content there Big All. I think the mods should edit this.big-all wrote:theres only one way to find outspeed wrote:are these powerfull enough to do that sort of work?
i assumed they were for light work,small screws eg
a sparky screwing backboxes on etc
plumber screwing pipe clips
joiner, hinge screws/ kitchens
50no 60mm screws is a lot for such a small battery?
fight
[appologies to those that dont watch harry hill
will try it out later then
It may seem difficult at first! But everything is difficult at first.
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
liven up the threadThe Weegie wrote:Inappropriate content there Big All. I think the mods should edit this.big-all wrote:theres only one way to find outspeed wrote:are these powerfull enough to do that sort of work?
fight
i think some off you are under the impression the drill is a small pistol shaped drill that you can hide in your hand its identical in size to the 14.4v brother
http://www.bosch-pt.co.uk/boptocs2-uk/T ... /index.htm
any way drilled a 35mm hole through 21mm timber with a new spade bit in less than 2 mins i personaly would prefer to use a 18 or 24v drill for this job especialy if it was through 2" joists
and the screws 1x 70mmx5mm and 66 8x2" silver wood screws on to 2" timber then i got bored 'took them all out again the battery was on flashing single bar
3 bars75%-100 charged
2 bars 50-75%
1 bar 25-50%
flashing bar less than 25%
- big-all
- Pro Carpenter
even though i have the full kit [excluding tin snips ] i was very but plesantly surprized at how big it was [ooeerr misses]
just for comparason the 14.4 spec and the 10.8 spec
Technical data
Torque, max. (hard screwdriving applications) 38 Nm
Torque, max. (soft screwdriving applications) 16 Nm
No-load speed (1st gear/2nd gear) 0 – 400 / 1.250 rpm
Chuck jaw width, min./max. 10 mm
Drill spindle thread 1/2"
Battery voltage 14,4 V
Weight incl. battery 1,3 kg
Torque settings 15+1
Drilling diameter
Max. drilling diameter in wood 25 mm
Max. drilling diameter in steel 10 mm
Screw diameter
Max. screw diameter 7 mm
Technical data
Torque, max. (hard screwdriving applications) 30 Nm
Torque, max. (soft screwdriving applications) 13 Nm
No-load speed (1st gear/2nd gear) 0 – 350 / 1.300 rpm
Chuck jaw width, min./max. 1 / 10 mm
Battery voltage 10,8 V
Weight incl. battery 0,95 kg
Torque settings 20+1
Length 169,0 mm
Drilling diameter
Max. drilling diameter in wood 19 mm
Screw diameter
Technical data
Drilling diameter
Screw diameter
Technical data
Length 169,0 mm
Drilling diameter
Screw diameter
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
jg wrote:I like the vid, looks quite good to me.
The Bosch multi construction bits will drill masonry, although it is easier with the hammer action switched on-
http://www.ultimatehandyman.org/video/t ... review.php
I might have to buy one of these 10.8v Bosch drills to test them out properly!
They certainly look good in the video.
On thing he said in the video was that the 10.8v Li-on had the same power as a 12v drill, which indicates that the batteries are more powerful. But when I tested out a dewalt 18v Li-on and a 18v ni-cad both batteries were almost identical.
I have a 12v Bosch drill, so I guess if I buy a 10.8v Bosch drill I could compare the two.
- big-all
- Pro Carpenter
10% more isnt a lot perhaps they are reffering to the fact that you get volt drop with nicads you have only to drop 1.08v to =a 10.8 lol
so maybe the fact you dont get fade so keep the even power over the range makes it equivilent
or indeed if the gearing is 10% lower you will get the equivilent output torque
Compared to the aeg 12 volt drill driver orange it does look very good,the aeg has a very big motor casing compared to the bosch 10.8 volt,what do you think big all you know all about the specs.
-- Sun May 09, 2010 2:42 pm --
Are bosch changing to 12 volt,is that why they are selling them off.
- big-all
- Pro Carpenter
cant find any specs for the aeg as in rpm torque ect
its from the ryobi stable [tti industrial ]as there pro range
it has a comprehensive kit but no add on tools at present
its a single speed machine
it has a 3 year warentee[on some sites]
has 1.5 ah batteries
the bosch has 2 speeds [0-400 0-1400]
has 1.3 ah batts
7 bits off kit [torch 'gop multitool'impact driver'tin snippers'1 speed driver '2 speed driver'angle drill] to collect
aeg is good value for money if they had all the tools that bosch have i would go for aeg but as they havent [for now at least] bosch is more flexable
has 1.3 ah batts
