Drill bit won't grab metal screw
Has thanked: 740 times
Been thanked: 2355 times
Re: Drill bit won't grab metal screw
is it possible to remove the component that the screw is in!!
4ap79ztl
Has thanked: 17 times
Post by 4ap79ztl »
big-all wrote:is it possible to remove the component that the screw is in!!
No ::b
I don't know for sure but i am thinking that a 1mm drill bit will stand a better chance of biting into the metal...................
-- Wed May 19, 2010 9:58 pm --
Hi all problem resolved, had to resort to drastic measures unfortunately.
For some reason the screw wouldn't drill whilst in the door.
I had to cut the door off as close to the screw as possible, i think i can buy just a new handle only for the door.
Upon opening the door up, i have found two other faults, joy of joys :?
Just thought i would keep you informed.
Thanks.............
