dot & dab aquapanel/ direct bond Aquapanel
Jaeger_S2k
Pro Handyman
Has thanked: 20 times
Been thanked: 27 times
Post by Jaeger_S2k »
Which is quicker? :grin:
Jaeger.
panlid
Been thanked: 1 time
Post by panlid »
plasterboard :thumbright: :lol:
Jaeger_S2k
Pro Handyman
:wink:
Jaeger.
bathstyle
Post by bathstyle »
Plasterboard is so much easier to cut and mount
panlid
Post by panlid »
jaegs if you look i never said any different. just pointing out that you can cut it exactly the same way.
Jaeger_S2k
Pro Handyman
Have to agree.
You just been antagonistic the whole time, nothing new then. :sad:
Jaeger.
panlid
Post by panlid »
i like to call it pedaantic :thumbright: :lol:
Jaeger_S2k
Pro Handyman
Well there's NO surprise! :wink:
Jaeger.
Hoovie
Borders Bodger
Been thanked: 4 times
Post by Hoovie »
panlid wrote:as i said before
aqua panel cuts in exactly the same way as PB. just score it with a knife and break
now if it is quicker is a totally different point.
let me know if you lot are struggling with it!
I am!
I can cut plasterboard just like you say, but I have been nearly 100% unsucessful in cutting aquapanel that way over any sort of length.
When I try the same thing with AP, the knife does not maintain a straight line even when I use it against a straight edge and the board does not snap. Usually end up taking a circular saw to it!
Now I am not a pro - obviously! - but I don't see it as "cuts in exactly the same way as PB" by any means
panlid
Post by panlid »
there is a difference in cutting the same way and it being as easy.
obviously if you are cutting a 2" strip off a board it wont work.
but if you want to do anything bigger then i dont have a problem doing it.
just do a light cut first with a knife and straight edge then remove the straight edge, run the knife down the cut a bit harder and snap it.
i have said all along it isnt as easy as P/B i am just saying you can cut it with a knife.
its english guys (accepted not always in its truest form) :lol:
Hoovie
Borders Bodger
Post by Hoovie »
panlid wrote:there is a difference in cutting the same way and it being as easy.
I have a couple more pieces to cut later today and will follow your suggestion :thumbright:
The first couple of pieces I did last week was taking 900mm boards to a 860mm width and I was very wary trying to snap it in case it took a 'wrong turn', as it were.
Cheers Panlid :thumbright:
Hoovie.
:salute:
panlid
Post by panlid »
sorry hoovie i should have stated that it only works for larger strips.
i also use a cordless circular saw to do a little bit.
bathstyle
Post by bathstyle »
Do multiple scores with a new stanley blade then snap. Then rasp off the rough edge :lol:
panlid
Post by panlid »
i only started to cut it like this more because with the circular saw it gives of a ridiculous amout of dust.
Hoovie
Borders Bodger
Post by Hoovie »
panlid wrote:i only started to cut it like this more because with the circular saw it gives of a ridiculous amout of dust.
Oh yes - my blade safety cover thingy is jammed open now with all the dust ::b
Return to “Tiling Forum”
