Space / gaps and mould behing shower tiles.
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Re: Space / gaps and mould behing shower tiles.
Post by wine~o »
royaloakcarpentry wrote:Sounds like you live in new Milton lol
Used to run an off-licence there..........old milton green..right opposite the wheatsheaf...
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
I lived in Ashley for a while with my gran and grandad as a child. Two minutes walk from the Woodpecker pub. My aunt has the bungalow now.
My little nana (great gran) Had a beautiful house near to barton. Can't remember if it was Spindlewood or that was name of house. Was down a little private gravelled road. Its a ruddy housing estate now. That beautiful house got knocked down to make way for it.
wine~o
Post by wine~o »
royaloakcarpentry wrote:I lived in Ashley for a while with my gran and grandad as a child. Two minutes walk from the Woodpecker pub. My aunt has the bungalow now.
Small world...New Milton now has more Chinese take-aways than the whole of China...
I might have made that up....but there were at least 9 last time I looked.. :shock:
jj74cycling
Post by jj74cycling »
Thank you once again. I am beginning to get a picture. I think the corners have been siliconed. As you can see from the next pic. I think the plasterboard did not go down to the shower tray far enough (it may have been cut too short). I am hoping (as the other tiles are fairly solid) I can fill the cavitiy with a cement style grout and fix the loose tile back in. However, 1) will the mould continue to grow? 2) as you can see from the other pic, I scrapped out the grout where there were cracks (it is here that I think water was getting through to cause the mould) - Can I just grout over the top / into the places where I have scrapped.
My wife says that the grout will let water through because it is porous, and this may allow the mould damp to begin again. is she correct?
The state of the shower has been like this (as per the pics) for 3 months and so has had plenty of time to dry!
Many thanks for your comments in advance
gap in grout small.jpg (32.42 KiB) Viewed 1202 times
wide gap small.jpg (49.75 KiB) Viewed 1202 times
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Post by Colour Republic »
Grout is water resistant not waterproof (unless it's an expoxy grout) tiny amounts can be absorbed through the grout into the substrate but if you have cracked grout it will pour in.
Use a flexible cement based addy and flexible grout
royaloakcarpentry
Normal grout is fine for shower use. We rip out shower enclosures that are 15 years old and plasterboard is immaculate as the day it went up. It is the workmanship and maintenance or leak that are normally at fault when things like this happen.
You need to make sure the shower tray is properly supported and not got excessive movement. Take off tiles until you get to good plasterbpard. Cut out damaged board, clean mould and let it dry out. re-board and tile.
Return to “Tiling Forum”
