Page 2 of 13
Re: Intergas 24/18 HRE compact Combi
Posted: Tue Dec 21, 2010 9:05 pm
by thescruff
Razor wrote:sounds more like a mecchano set than a boiler :lol:
Oh I hope so haven't played with one of them since I was about 13. :lol:
Posted: Wed Dec 22, 2010 1:01 pm
by Agile
Welcome to the 21st Centuary!
The water in the Bath area can be quite hard.
If the secondary tubes get blocked with lime scale the only solution is to treat them in situ with acid ( unless you replace the entire heat exchanger! ). No simple plate to change/clean!
I recommend you fit a good magnetic scale reduce in the the cold water inlet.
Tony
by Agile
I hope you are fitting TRVs and all the other modern controls!
Funny time of year to be changing a boiler when its freezing!
Tony
Posted: Wed Dec 22, 2010 1:22 pm
by thescruff
Agile wrote:I hope you are fitting TRVs and all the other modern controls!
Tony
Whilst I probably will change it now, the plan was to get it in ready for any emergency because it's so damn cold.
Plan B, was because the gas has gone up 300% since this time last year.
Plan C was the less I give the vultures in gov.con the happy I am.
Posted: Wed Dec 29, 2010 11:06 pm
by Agile
The Government are not involved in your choice of new boiler.
Its your wallet which pays the bill and its you who will see all the savings!
Hurry up and get it in while its warm!
Tony
Posted: Wed Dec 29, 2010 11:12 pm
by Razor
If you're in a hurry get a BG crew round, conventional to combi is about 13 hours labour inc flush :shock:
Best of the best :huray:
And don't fit an inline scale inhibitor but the hydroflow doobries seem to work (a bit) :wink:
Posted: Wed Dec 29, 2010 11:19 pm
by thescruff
I'd love to see BG try and flush a 36 year old system with the original water init :lol:
Think it may need a wire brush on a flexible rod. :roll:
If I tried hard I could doitall myself in less time that that.
Posted: Wed Dec 29, 2010 11:47 pm
by Razor
They would probably give you a powercleanse - 24 minutes for that
Or full flush up to ten rads - 2 hours 20 minutes :lol:
Posted: Wed Dec 29, 2010 11:59 pm
by thescruff
Razor wrote:They would probably give you a powercleanse - 24 minutes for that
I may borrow my BG mates flue gas gadget for an hour while he's drinking the coffee. :roll:
Posted: Thu Dec 30, 2010 12:00 am
by Razor
Well he's not an installer then they don't have them :lol:
Posted: Thu Dec 30, 2010 12:06 am
by thescruff
He's a healer, duster and drop an aspirin in the header tank.
Posted: Thu Dec 30, 2010 12:08 am
by Razor
And don't forget sticking his probe up some old dears flue!
Whatever happened to Dickie :lol:
Posted: Thu Dec 30, 2010 12:13 am
by Mehran2
well that is interesting John as I would direct you to section 9.1.4 on page 28 of the manufacturers instructions for a intergas HRE boiler.
which i would quote for you:
9.1.4 Combustion
The combustion for this appliance has been checked, adjusted and preset at the
factory for operation on the gas type defined on the appliance data plate. No
measurement of the combustion is necessary
. Do not adjust the air/gas ratio valve.
now it does tell you what the reading should be if you so wish to check :wink: I would check anyway just in case :lol:
Posted: Thu Dec 30, 2010 12:15 am
by thescruff
I think Dickie is just about banned everywhere now :lol:
Posted: Thu Dec 30, 2010 12:17 am
by thescruff
Mehran2 wrote:well that is interesting John as I would direct you to section 9.1.4 on page 28 of the manufacturers instructions for a intergas HRE boiler.
9.1.4 Combustion
I ain't got it yet Mehran to read 9-1-4 combustion, but you can be sure I will at some time. :roll:
I think they shut down for Christmas. ::b
