How to remove a ground anchor
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: How to remove a ground anchor
Post by royaloakcarpentry »
Pneumatic breaker............do the concrete and lift it out, then repair.
These users thanked the author royaloakcarpentry for the post:
Mr Red
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Borrow a 5" grinder, get a couple of thin discs.
Abrasives discs will even cut hardened steel.
5 mins tops and its gone.
These users thanked the author Hitch for the post:
Mr Red
scot-canuck
Has thanked: 247 times
Been thanked: 314 times
Post by scot-canuck »
Cobalt Drill bit? Would that be hard enough to drill the bolt heads out? Other option is cutting it with a torch but unless you know what you are doing , I wouldn't recommend it.
These users thanked the author scot-canuck for the post:
Mr Red
Gone M.I.A.
Return to “General DIY forum”
