pc has become very slow
root
Has thanked: 168 times
Been thanked: 173 times
Re: pc has become very slow
Post by root »
nope should be free ware...
the app should give you a list like this.
The rule is to disable non-Microsoft context menu handlers *one-by-one* and verify if the problem is solved. If disabling one does not solve the problem, undo the disabled item and disable the next non-Microsoft handler. Do the same until the problem is solved and finally identify the culprit. Scroll right to see the Company Name column in ShellExView.
http://www.nirsoft.net/utils/shexview_setup.exe
NOTE: It's not always the Context menu handler, but a PropertySheet handler or an Icon Handler may be the culprit sometimes.
if all else fails try running sfc /scannow to fix the problem, although this will take about 45mins to an hour to run on some systems.
These users thanked the author root for the post:
southwood3
- Dave
southwood3
Lemming
Has thanked: 38 times
Been thanked: 43 times
Post by southwood3 »
root wrote:nope should be free ware...
Thanks. I didn't get anything like you've posted so will try it again.
root
Post by root »
may have downloaded something else and not the app :-) websites seem to be very good at misleading people from the actual application you are looking for.
southwood3
- Dave
southwood3
Lemming
root wrote:may have downloaded something else and not the app :-) websites seem to be very good at misleading people from the actual application you are looking for.
Bingo! After disabling and enabling loads on the list I finally got to this one:
Express Zip File Compression Software Yes Context Menu No No No No No No C:\Program Files\NCH Software\ExpressZip\ezcm.dll {8EEA165E-0B8B-4BA7-9796-50214C767171} 26/04/2011 10:26:22 26/04/2011 10:26:23 No *, .cab, .rar, .zip, Folder A 768,512 No
......and the problem has now gone. Many thanks Dave. This has been bugging me for ages. :thumbright:
root
Post by root »
no probs glad it helped :wink:
- Dave
fitzy
CLOSED ACCOUNT
Has thanked: 871 times
Been thanked: 757 times
Post by fitzy »
Maxsys wrote:Check this first http://www.bleepingcomputer.com/forums/topic87058.html, also what PC is it, make model, RAM installed and OS.
Its a Dell Dimension 5100, Pentium 4, 0.99 GB RAM and its on Windows XP. The Pc is around 5 yrs old.
Return to “Computers”
