Cutting Laminate Flooring around Toilet Base
Tryanything
Been thanked: 4 times
Post by Tryanything »
Sounds a bit drastic but have cut some off the bottom of the pan before :shock: with diamond blade slight chipping covered by mastic joint :-)
There would be less trouble in the world
if l had not had six daughters
Hoovie
Borders Bodger
Post by Hoovie »
WOW! Definately too drastic for me!! :shock: :lol:
tim'll fix it
Been thanked: 1 time
Post by tim'll fix it »
I am sorry tryanything but that is one of the most stupid things I have ever heard
if you are going to go to that ammount of effort then just raise the pan
Hoovie
Borders Bodger
Post by Hoovie »
OK - Followed some of the advice here ( and not all as some beyond my abilities) and flooring is down. Me and the Boss are happy with it (just got new skirting to fit now).
Made up template from Cardboard ... I cut lots of slits in it so it could take on the shape well. Then when got shape, used a marker pen to draw outline read for trimming:
This is the template for the rear of the pan
Cut out flooring using template:
This is front of pan plus awkward bits for non-stright wall and architrave
And this is finished floor (except Skirting, Threshold a sealent around Pedesal and Pan):
Main Run -
Area between Bath and door where Basin and Toilet are -
Alternate view -
I spent a bit of time working out best way to have the tile pattern and be able to fit around the sanitary ware and this seemed to work out best.
So cheers for the Advice :thumbright: Mucho Appreciated :grin:
Tryanything
tim'll fix it wrote:I am sorry tryanything but that is one of the most stupid things I have ever heard
Hi tim'll fix it
I did say drastic, problem i had was underfloor heating had been put on original floor and already raised using offset multiquicks just couldn't get anymore on the height without making adjustments to cast iron stack so just took 10mm off bottom of pan, I know it sounds drastic but cant see any problem with it
Tryanything
Nice one Hoovie looking good :thumbright:
