Very nice work, sensible layout of tiling and looks like you matched the levels of the thinner mosaics nicely with the tiles surface, can't stand it when they're set back
Looks like the grouting wasn't finished completely in the last pic?
Bathrooms galore
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
- Has thanked: 104 times
- Been thanked: 490 times
Re: Bathrooms galore
Yes, luckily the mosaics were about the same thickness as the tiles. I usually advise the client to get tiles and border of a similar thickness if possible.Razor wrote:Very nice work, sensible layout of tiling and looks like you matched the levels of the thinner mosaics nicely with the tiles surface, can't stand it when they're set back
The grouting is complete in that pic except that it's grey and not white which makes it look slightly odd.
- Has thanked: 39 times
- Been thanked: 621 times
My top tip of the day.......
Thick tile and thin mosaic. Fix cheap thin contract tiles and then mosaic on top.
- Crooksey
- Been thanked: 72 times
Stupid amounts of adhesive (keraflex), then float flat with a level and put mosaics in.royaloakcarpentry wrote:My top tip of the day.......
- Has thanked: 77 times
- Been thanked: 335 times
I like the dark wood built in one.... what wood is it based on, assuming its a laminate?
All excellent work though
