Playhouse base
- BANNED
- Has thanked: 216 times
- Been thanked: 1070 times
- BANNED
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Playhouse base
I don't have a play house - and that's Norfolk.BillyGoat wrote:
Don't want to worry you, but your play house seems to have blown away or stolen by Arabs!!!!!
BG
I quite deliberately posted a pic of something totally unrelated to either playhouses (or work).
- ayjay
Re: Playhouse base
It is very small.cotswold builders wrote:I can see its worked but the photos to small.
Is it larger on your PC?
- BANNED
Re: Playhouse base
I just copied it from 2 faced book, it was the same size but could be enlarged on there.ayjay wrote:It is very small.cotswold builders wrote:I can see its worked but the photos to small.
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Re: Playhouse base
Cotswold I've managed to upload 2 photo's....both by luck I've got an ipad and it's a mare!! Plus I'm pash with computers
- ayjay
Re: Playhouse base
You need to enlarge it before you copy it.cotswold builders wrote:I just copied it from 2 faced book, it was the same size but could be enlarged on there.ayjay wrote:It is very small.cotswold builders wrote:I can see its worked but the photos to small.
