if you happy dont worrybean wrote:Still a little unsure what you mean. Do
You mean adding another length of moulding to the top, similar in style to the one across the top of the cupboard? To make the top heavier and more chunky?
its personal taste
assuming your timber is say 15-21mm aim to add say 40-44mm molding to the the top front about 6mm up from the bottom off the top so you have a 6mm step similar to a door frame on the top part
usually if i build a unit what ever is at the plinth at the bottom like a swirly/wavy design will be replicated under the top
the top will tend to be higher up allow the detail to give a similar or proportionate spacing to other shelves
