Dimmer switch
markysparky
Electrician
Contact:
Post by markysparky »
Even though you need a new dimmer switch this wouldn't cause it as only the light the dimmer controls wouldn't work.
No fuses blown, no loose connections and no junction boxes.
Haven't had any problems with mice by any chance?
Your wife turned on the light, there were sparks and the lights went out. This tells me that the fault is at the fan light!
Only other thing it could be is that the lights are fed from the plugs off a switched fused spur and this is the fuse that has blown. But this is highly unlikely! :?
Rich Sum
Post by Rich Sum »
Cheers again
If I get home from work before it gets dark tomorrow, I will check the fuse box and fan light.
Cheers
Richard
www.koitalk.co.nr
doidiy
Post by doidiy »
Have you fixed it Rich ?
I couldn't sleep last night as I was thinking about it. Luckily I am not allowed near electrics :lol:
Rich Sum
Post by Rich Sum »
Hi Doidy
Not fixed yet It was too dark when I got home, b****y traffic. :cry: I will have to get a good torch for when I turn the power off.
Have you tried tyyyping inthe darkkk :lol: :lol:
Cheers
Richard
www.koitalk.co.nr
doidiy
Post by doidiy »
It is easier typing in the dark than fixing lights in the dark.
Rich Sum
Post by Rich Sum »
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
Great smiley Doidy
Cheers
Richard
www.koitalk.co.nr
amarg
Has thanked: 12 times
Been thanked: 32 times
Post by amarg »
It was posted on here months back, I right clicked and saved it and have been waiting to use it :lol:
Stella
Has thanked: 3 times
Post by Stella »
:scratch:
Rich Sum
Post by Rich Sum »
Ok heres an update
I have checked the fuse box for loose connections all ok. When I turned the power back on the lights were working, :grin: :grin:
After turning the lights on and off a few times I got a shock from one of the switches, which was then replaced and the lights tried again. They worked ok a few times but then started flickering. :? :?
I decided to change all the light switches thinking more than 1 was faulty. again the power was turned back on. the lights were turned on and off again, the lights flickered again and went off, Now i`m back to square one and have nothing. :? :cry: :cry:
Is it possible the cable is shorting out some where in the circuit :?:
Cheers
Richard
www.koitalk.co.nr
tim'll fix it
Been thanked: 1 time
Post by tim'll fix it »
have you done any drilling or put any pictures up recently ?
Rich Sum
Post by Rich Sum »
No nothing at all
Cheers
Richard
www.koitalk.co.nr
Rich Sum
Post by Rich Sum »
What is going on
Been sitting here on the pc and the wife has gone into the bedroom and the light is on. wierd :? :? :? :? :?
Cheers
Richard
www.koitalk.co.nr
tim'll fix it
have you consider the possibilty of ghosts :wink:
I would call a spark, I think you will have a simple problem somewhere that could take us days to find over the internet and spark a few mins
tim'll fix it
Rich Sum
Post by Rich Sum »
Thanks Tim looks like thats what i`ll have to do. Do you think it si safe to leave the lights on while they are working :?:
Cheers
Richard
www.koitalk.co.nr
Locked
Return to “Lighting”
