Best way of removing skirting boards
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Only-Me wrote:http://www.diytools.co.uk/diy/Main/Prod ... ctID=23818
This is what a lot of carpet/laminate fitters use..............then you would'nt have to remove skirtings. Not sure if you can hire them, but you maybe be able to ring around a few fitters
The links does not work :??
No matter what you do it takes you to to the homepage! Weird :??
tim'll fix it
Been thanked: 1 time
Post by tim'll fix it »
link worked for me last night
tim'll fix it wrote:link worked for me last night
It keeps redirecting me to the homepage, even if I copy and paste it in the address bar :??
Only-Me
Been thanked: 3 times
Post by Only-Me »
:roll:
tim'll fix it
yes sorry tonight it takes me to the main page. I didnt check at lunch :oops:
JLukins
Oops
Post by JLukins »
I've just taken off one skirting board. See images for the disaster....
It was taken off just behind the front door and as you can see there is no plaster left. I can see down behind the skirting to the left and it looks the same. Surely this is too much debris and damage to expect to be able to use Smooth Over to fit new skirting boards.
I also started to take one off in the living room and whilst it doesn't look as bad (around a fireplace) it also doesn't look like there is any plaster beneath the skirting board.
Any suggestions? Beading?
I think beading may be your best option.
At least you can easily fix them back on, use some mortar to re level the wall, where the plaster has come away and then Glue the skirting back on with some grab adhesive. Then go and get some beading, it will look ok as long as it is fit correctly.
dirtydeeds
Craftsman Carpenter
Post by dirtydeeds »
removal of skirting board in hard to get at areas such as behind radiator pipes is dead easy
use a fien multimaster
i hear people complain that the blades are expensive, so what, its quick
AND if its a demolition job, who cares, use an old blade
JLukins
Change Of Plan
Post by JLukins »
We've just taken the carpet up and noticed we have block flooring!!! B*gger doing laminated floor.
We want to sand it and re-varnish or just clean it up. What can we use to clean it? Also, what can I use to fill in any gaps, particularly by the skirting boards and are there any other things to watch out for?
Piccy attached.
dirtydeeds
Craftsman Carpenter
go on give us a clue
the link wasnt good, it only goes to the home page
i tried searching for product 23818 and the search engine on the site couldnt find it
