Start to Finish Solid Oak Herringbone Floor
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Re: Start to Finish Solid Oak Herringbone Floor
Post by steviejoiner74 »
Cracking job wes! Fantastic workmanship indeed! :thumbright: I've got that flooring in my living room although it's original parquet and 60 years old!
These users thanked the author steviejoiner74 for the post:
Wes
getthewheelsinline
Has thanked: 224 times
Been thanked: 182 times
Post by getthewheelsinline »
Attention to detail is commendable! No wonder the client is pleased!!
Any part of it you are not 100% with? Or would have done differently. ?
Bikergirl
Has thanked: 100 times
Been thanked: 133 times
Post by Bikergirl »
Brilliant job, and so worth doing properly.
At the church where I used to work, the parish hall was once the primary school and had 100 year old parquet. We had it sanded and re sealed, and it looked like new by the time they finished. Definitely an investment for the future.
Wes
Wood Flooring Installer
Has thanked: 379 times
Been thanked: 565 times
Post by Wes »
getthewheelsinline wrote:Attention to detail is commendable! No wonder the client is pleased!!
Thanks Cal :thumbright:
Yes there is a part I would have done differently. Well, more of a school boy error really. I forgot to pay special attention to the fire heart! I normally do, but with all that went on with this floor, I just forgot. Anyway, when the hearth went in, there was a 5 mm gap at one side. I hadn't set markers for perfectly level, specifically in that area. I think I must have got carried away with how good the self levelling products were I perhaps thought the hearth didn't need to be checked. Won't be happening again! I had to use a black sealant to disguise the f@k up (Possibly just visible in the hearth pic). Not my finest moment :roll:
These users thanked the author Wes for the post:
getthewheelsinline
Wes
Post by Wes »
Bikergirl wrote:Brilliant job, and so worth doing properly.
Thanks bg :thumbright:
Yep, they really are long term floors and are simply timeless IMO. Well worth the money :-)
Bill Darr
Has thanked: 18 times
Been thanked: 44 times
Post by Bill Darr »
Great job - did you use just a trowel and spiked roller to lay the SLC?
Wes
Post by Wes »
Thanks Bill. Yes we did. We also used 'screed level pins' (measured using the lazer and staff method - you can actually just see one of them in the first 'mesh' picture - top right and red) to help gauge the deeper areas when we applied the K301. It doesn't look like it but we had to build a lot of the floor up by 15 mm or so.
We couldn't use the pin roller all the time, as the depth was to great with the K301. The pin roller just creates a kind of bow wave. Hope that answers your question mate.
Oh, I would add, we've just installed a 30 mm depth self levelling on another job and actually used a garden rake (the thin wire type) to run through the levelling and it worked a treat :-)
BRUNO
Has thanked: 34 times
Been thanked: 67 times
Post by BRUNO »
will have to take a look at that ardex, have you ever used F ball gear for the SLC? brilliant job fair play to ye, so so much better than tiles or laminate.they used to use bitumen didnt they, is the adhesive you used cement based or got a bit of flex to it?
These users thanked the author BRUNO for the post:
Wes
Wes
Post by Wes »
BRUNO wrote:will have to take a look at that ardex, have you ever used F ball gear for the SLC? brilliant job fair play to ye, so so much better than tiles or laminate.they used to use bitumen didnt they, is the adhesive you used cement based or got a bit of flex to it?
Used f-ball slc loads Bruno. We're using a full f-ball spec on our current job. F77 and stopgap 300 HD. Can't fault either Ardex or F-ball gear. Although, f-ball are more geared towards toppings whereas Ardex also cater a little further down with screeds etc. F-ball is a little better on price..
I'm not a big fan of the older bitumen specs. I've ripped too many of them up :-)
The adhesive I mainly use are modified silicate types (http://www.rewmar.co.uk/rewmar-ms-polym ... sive-16kg/)..It gives excellent allowance for seasonal shift (exceptional elasticity). The problem with the older bitumen types is they were prone to tearing as they would go brittle over the years, causing an opening for moisture and just generally de-bonding...Not all the time of course..
Chris Skilbeck
Has thanked: 132 times
Been thanked: 238 times
Post by Chris Skilbeck »
Beautiful work, Wes - I'll give you a call when I win the lottery . . .
How long did the customer have to clear out for?
These users thanked the author Chris Skilbeck for the post:
Wes
Wes
Post by Wes »
They hadn't moved in yet. It was a big renovation project...They didn't get much change out of 10 big ens for the floor :-) Give me a call when your numbers come up :wink:
Chris Skilbeck
I'm just going to check them now . . .
BillyGoat
Troll Headbutter
Has thanked: 386 times
Been thanked: 796 times
Post by BillyGoat »
Wes wrote:
kellys_eye wrote:You may be a floppy hatted tw@t Wes but, by Christ, that's a fecking good job :thumbright:
I'd hire you in an instant.
Sorry, I meant, I'd hire you FOR an instant :mrgreen:
I make a cracking brew, but I do charge day rate :lol:
That's the first time I've been called 'a floppy hatted tw@t' :lol: Maybe it'll stick :mrgreen:
Cracking job Wes, you worked hard for that days wage! :thumbright:
BG
Wes
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Looks great, especially the skirtings :wink:
Why did you bliind it up with sand. Does it add strength to the primer coat?
Top job :thumbright:
philprime
Has thanked: 77 times
Been thanked: 247 times
Post by philprime »
Fantasic job there wes, how long did the job take
Return to “Show Case Gallery”
