Lidl Tools Monday 29th June
The Bargain Tool forum. This is for regular members to post about bargain tools. It is not for spammers to post links to tool sites!
Dickie
Has thanked: 893 times
Been thanked: 729 times
Re: Lidl Tools Monday 29th June
Post by Dickie »
p4ult wrote:I found both the nails and staples didn't fully go into the wood. Then I tried pushing down with force on to the gun when firing, both now fully penetrate the wood
Paul
Of course with using a Passy finishing nailer this is a given, but I even tried holding this tool very firmly & it still did not bury nails. The Max setting is just not powerful enough - which is no surprise really.
I understand this can be a problem with battery nailers, the DeWalt for example.
Time-served Plumber/Heating Engineer & general wind-up merchant.
The Plumbers Anthem
If you have found my help or tips useful please donate here. Thank You;
Gas Safe RGI
Scottish, British & Proud.
I'm not or never claimed to be Chris Williams.
Job and Knock
Old School Chippie
Has thanked: 742 times
Been thanked: 1573 times
Post by Job and Knock »
Dickie wrote:Of course with using a Passy finishing nailer this is a given, but I even tried holding this tool very firmly & it still did not bury nails. The Max setting is just not powerful enough - which is no surprise really.
It depends, really. The DW guns are streets ahead of most battery nailers (e.g. Tacwise, AEG, Bosch, etc) with the 16ga gun generally being good for 50mm in softwood/MDF (sufficent for most skirtings, architraves, etc) whilst the 18ga gun does 40mm with no problems (50mm can be a bit trickier)
p4ult
Has thanked: 12 times
Been thanked: 38 times
Post by p4ult »
Here Dickie, I just fired off a few to show you.
As you can see, Three have more or less fully penetrated the wood when I leant on the gun, unfortunately this leaves marks on the wood.
The Two I put minimal pressure on the gun haven't full penetrated.
Paul
These users thanked the author p4ult for the post:
Dickie
Dickie
Post by Dickie »
More bargains this coming Thursday;
http://www.lidl.co.uk/en/our-offers-2491.htm?id=620
These users thanked the author Dickie for the post:
The Plumbers Anthem
Gas Safe RGI
Grumbledook
Has thanked: 1 time
Been thanked: 15 times
Post by Grumbledook »
Think those blades will fit the tracksaw they had a few weeks back?
Has thanked: 736 times
Been thanked: 2341 times
they dont say what the bore is so no telling :dunno:
Dickie
Post by Dickie »
Grumbledook wrote:Think those blades will fit the tracksaw they had a few weeks back?
You over 18 fella???!! :lol: :lol:
Why the feck do you need to be over 18 to buy a circular saw blade??
Not sure GD, it doesn't state the hole size in that advert.
The Plumbers Anthem
Gas Safe RGI
it about a ratio off 5.2 in the picture so iff we assume the blades are 160mm then that puts them at 30.7 bore so will be 30 bore :thumbright:
blade picture on screen 75mm hole 14.5mm
use reducing washers if you bore is less
http://www.tooled-up.com/microcat/circu ... shes/3490/
These users thanked the author big-all for the post (total 2):
DickieGrumbledook
Rating: 14.29%
Rorschach
Has thanked: 109 times
Been thanked: 1038 times
Post by Rorschach »
They don't mention bore size, aso the track saw uses a 165mm blade so it would reduce your depth of cut a little. I'll be looking however and if the bore size is big enough I'll probably grab some for rough work.
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Post by London mike 61 »
Does anyone know if the Sds drill is any good? I don't have a need to use it every day and it will only get occasional heavy use.
The price is good, I just need to get to a store before the other blighters get there first and clear the shelves!!
Rorschach
Post by Rorschach »
Those SDS are usually perfectly fine for the money. I have the Aldi version and it has seen some hard work and still works great. They tend to be very heavy but for occasional use it's ok.
These users thanked the author Rorschach for the post:
London mike 61
Dickie
Post by Dickie »
London mike 61 wrote:Does anyone know if the Sds drill is any good? I don't have a need to use it every day and it will only get occasional heavy use.
For 40 quid & a 3 year warranty it's got to be worth a punt!!!
London mike 61
The Plumbers Anthem
Gas Safe RGI
London mike 61
I have read some reviews on this drill and other lower priced drills and they all seem to have difficulty in holding the chisels in the chuck , they appear to fall out while the drill is in use.
Is this something only the cheaper drills suffer from or is it just the design of these drills that makes retaining the bit in the chuck more difficult?
Also , a lot of the reviews of the lower priced drills say that after a short while using the chisels , the drill has burnt out. Does anyone on here have any experience of using one of these for non heavy use and the drill burning out?
I know £40 isn't a fortune to spend on a Sds drill , and I won't use it to extreme but I don't want to have the drill burn out removing small areas of plaster or whatever.
Any comments are gratefully appreciated.
Mike
Dickie
Post by Dickie »
Sorry Mike, like others I bought the Aldi equivalent & not used it much on chiseling, so can't really comment.
London mike 61
The Plumbers Anthem
Gas Safe RGI
Rorschach
Post by Rorschach »
London mike 61 wrote:I have read some reviews on this drill and other lower priced drills and they all seem to have difficulty in holding the chisels in the chuck , they appear to fall out while the drill is in use.
Mike
Neither drills or chisels have fallen out of my aldi version.
London mike 61
Return to “Bargain Tools”
