SIP 01478 1/2" router
This forum is for reviews of Budget power tools such as B&Q / Wickes own brand, Direct power / Titan / challenge / Performance power / Erbauer / Skill/ Bosch Green / Black & Decker
PLJ
Re: SIP 01478 1/2" router
Post by PLJ »
yes, i think most of the 8mm cutters i have are that style, as are the few 1/4" ones.
Never thought about teflon spray - how will that stuff help,. big-all ?
Has thanked: 736 times
Been thanked: 2342 times
reduces friction
cleaner cuts less build up on cutters
if you get resin or anything sticky on the surface that will grip the router base it reduces that as well
PLJ
Post by PLJ »
I'll invest in some of that there teflon spray then !
Job and Knock
Old School Chippie
Has thanked: 742 times
Been thanked: 1573 times
Post by Job and Knock »
big-all wrote:sleeves are fine hitachi use them as many others :lol:
Yes, they are so fine that with large diameter cutters you invariably get slipping on heavy cuts and spirals can pull out completely in heavy cuts. In engineering terms they are simply a bodge and need to be used with care, ensuring that the cutter shank, reducer and collet are all clean and rust free and they need to be tightened carefully. Just a personal opinion, mind you, although I'm far from alone in holding it
to be fair i have seldom if at all used a 1/4 cutter in 1/2" reduction sleeve as i have enough routers to match the weight and power to the job
i just assumed if hitachi where happy it was a reasonable practice :lol:
Return to “budget power tools ”
