Was an epic build - the talk of the town! Yes - I meant to write 'Cylindrical turret'...I must still have been wind swept!! [emoji6]big-all wrote:fantastic job
quite awesome and amazing
and technically its a round tower with a conical roof is it not
Conical Roof onto Conical Turret!
- getthewheelsinline
- Has thanked: 224 times
- Been thanked: 182 times
Re: Conical Roof onto Conical Turret!
- wine~o
- Has thanked: 1415 times
- Been thanked: 4030 times
- These users thanked the author wine~o for the post:
- Has thanked: 37 times
- Been thanked: 3 times
Wow... amazing to see it go up.
Sent from my SM-N910F using Tapatalk
- These users thanked the author macdadi112 for the post:
- Has thanked: 58 times
- Been thanked: 18 times
wow! I was really not expecting to find a project like this, quite impressive! I did not have any sound over here but you can tell it was windy for sure. definitely dramatic! congrats on this unique project! I bet it will last for quite a while!
ps: the younglings are more than cute, great photo. are they the best helpers or what? :)
- These users thanked the author DmitriKara for the post:
Thanks. Yes they enjoy helping out their uncle! [emoji106]DmitriKara wrote:wow! I was really not expecting to find a project like this, quite impressive! I did not have any sound over here but you can tell it was windy for sure. definitely dramatic! congrats on this unique project! I bet it will last for quite a while!
- Has thanked: 201 times
- Been thanked: 518 times
Very impressive and I'm pleased it all went well. A couple of decades ago I worked on the restoration of st Philips cathedral in Birmingham and the cuppola was lifted off to be repaired . It sits on six legs or columns and a template was made to locate steel brackets fixed to the cuppola to those legs. It was lifted up and fitted literally perfect. A 3inch square stainless bar was then tapped gently into a slot in the central post of the cuppola using the crane as a large but delicate hammer. The function of this piece of steel was to hold a cross. Most of us had gone down for a cup of tea when the site agent burst in saying the cross was 60* out. It seems the template had been turned round by one leg . We seem to think it was a deliberate action by one guy rather than an accident but impossible to prove. Anyway we had to sort out the problem there and then owning to the cost of the crane if nothing else so it was all hands up there to jiggle the joints and turn the cuppola round. It's ok now just in case anyone stops to look.
- These users thanked the author Grendel for the post:
- Has thanked: 379 times
- Been thanked: 584 times
very impressive
- These users thanked the author transitboy for the post:
- Has thanked: 77 times
- Been thanked: 335 times
I'm a bit late on this one
Nice little job that
Who supplied the rolled UB? Rolled in two halves I gather?
Lifting eye threaded into an end cap on the CHS?
The steel brackets around the bottom, eaves, were they fabricated or cut and folded into the UB?
Them crane drivers start panicking at a little bit of wind dont they, when the cables start slapping at the jib they get proper upset
- These users thanked the author Hitch for the post:
Hitch wrote:I'm a bit late on this one![]()
Nice little job that![]()
Hi Hitch,
Base ring beam is 178x102x19UB and was rolled in two halves.
Lifting point was a 50mm bar welded through the 219CHS @100mm below end. Lifting sling was fed down tube & under the bar.
Brackets were 50RSA and welded to top of beam. Pre drilled to accept wood rafters.
We use that crane company frequently and most of the crane operators are pretty good to be honest.
Thanks, Callum
- Has thanked: 45 times
- Been thanked: 29 times
Another belated post as this thread has been revived.
Cracking bit of work and yes that lift looked pretty freaky for the guys. Crane with its extending cab looked like an interesting bit of kit it its own right
- These users thanked the author M1ke_a for the post:
