Mystery Object!
- wine~o
- Has thanked: 1415 times
- Been thanked: 4024 times
Re: Mystery Object!
Not an electrical measurement tool either... Hmmmm..
- These users thanked the author wine~o for the post:
- sheilamary3
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Mystery Object!
Have you tried it on a live cable? Not on live ends, just put a cable that's running to an item using power between (and touching) the metal bits.sheilamary3 wrote: A guitarist friend of mine didn't recognise it and just wondered if it was something that measured the power in a cable perhaps
Does it have a battery compartment?
Is it heavy for it's size?
- These users thanked the author ayjay for the post:
- sheilamary3
- surrealdeal
- Has thanked: 21 times
- Been thanked: 40 times
Re: Mystery Object!
The shape of it seems to suggest that it is pushed onto something that may vary in size and guided down onto the lug in the centre and thus activating the counter, cable counter maybe? Might only be for factory use.
- These users thanked the author surrealdeal for the post:
- sheilamary3
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Re: Mystery Object!
Mini flyswatter (with kill-counter)?
- sheilamary3
- kellys_eye
Re: Mystery Object!
It obviously 'counts' hence the resettable counting display.
I suggest each count happens when an item is pushed between the 'forks' making the two inner wires touch the two outer.
Being hand held it looks like it's pushed onto 'something' - the item to be counted.
The counted item is non-conductive - else the contacts would register a hit as soon as it was placed against it.
It 'may' be used to count the width of something - organic perhaps???
- sheilamary3
- Has thanked: 1300 times
- Been thanked: 1175 times
Re: Mystery Object!
More (probably useless) thoughts.
Some sort of electronic game.
Something that twists something together, and counts the turns.
Microwave leak detector.
It doesn't look industrial to me.
More 80s domestic.
More 80s domestic.
- These users thanked the author Dave54 for the post:
- sheilamary3
- Has thanked: 154 times
- Been thanked: 4 times
Re: Mystery Object!
No nearer! tried the cable idea and it doesnt react. Touched the prongs also with things of various thicknesses etc. The only thing that moved the counter was when I held it over some steam in a pan but it wasnt temperature related, It looks like it may contain a battery but there is just one of those minute screws that is too difficult to move. Its not possible to prise it off as you can with normal batteries . I have drawn a blank!! Thanks all for your suggestions .
- surrealdeal
Re: Mystery Object!
If the reading moved when over steam from a pan I wonder if it's some sort of moisture content meter for something, that basically gets a reading from the resistance of anything touching the bars. Or a salinity meter or something along those lines?
- Has thanked: 105 times
- Been thanked: 878 times
Re: Mystery Object!
I was going to suggest a temperature measurement gauge will have a look see.................
Looking at it from a design point it has 2 probes at a set distance apart so its measuring some sort of fluid by detecting resistance or capacitance - the shape may be a clue, a lobster claw ? or that maybe a curve ball
salinity meter (salt content in water)
Re: Mystery Object!
It doesn't react to rotation. I have decided that whatever its purpose is, I have absolutely no use for it!! I shall be donating it back!
- toolbox
- Has thanked: 129 times
- Been thanked: 210 times
Re: Mystery Object!
Well that's another 20 mins on Google I will never get back
Tried lots of parameters but no luck,. My guess is (assuming the wires do not heat up when operated) it is a very cheap and decidedly dodgy tester either for current or voltage in a cable or for testing a microwave.
Do let us know if you ever find out
- These users thanked the author toolbox for the post:
- sheilamary3
- BillyGoat
- Troll Headbutter
- Has thanked: 386 times
- Been thanked: 796 times
Re: Mystery Object!
Try sending it to BigClive on youtube.....he can take it apart and figure out what's inside and what it does!
BG
BG
- Has thanked: 108 times
- Been thanked: 1038 times
Re: Mystery Object!
oh yeah great idea, and if nothing else it will be an amusing video full of smut!BillyGoat wrote:Try sending it to BigClive on youtube.....he can take it apart and figure out what's inside and what it does!
BG
- These users thanked the author Rorschach for the post:
- sheilamary3
