Vauxhall movano new engine non starter
Bob225
Has thanked: 105 times
Been thanked: 878 times
Re: Vauxhall movano new engine non starter
Post by Bob225 »
drain and fresh, if its supermarket diesel it tends to have more ethanol and sulphur in it what makes it more hydroscopic
if you feel there are no mechanical issues - start looking at electrical
I don't have the electrical diagrams at hand to look at...…………..yet, as you can apperciate its hard to diagnose without seeing it
edit. check the in tank fuel pump is running/priming and check that its getting power
Chillman89
Has thanked: 3 times
Post by Chillman89 »
Thank you for advice currently running through these tests will up date but timing seems all good havent done fuel yet but still put off as runs perfect but still doing a few tests
