New Nest install Hot Water not working
ashc18688
Re: New Nest install Hot Water not working
Post by ashc18688 »
Wiring diagram from Nest is fine, I've fitted in excess of 400 of these as a nest pro installer. More than likely the electrician has wired it up wrong in the first place and then not checked his wiring, the amount of units I have been out to because of incorrect installation from third parties is crazy.
2 and 5 are always perm Live
3 and 6 are always demand
So for heating 2 and 3 are to be used, Hot water is 4 off, 5 perm live and 6 On.
1 is not required for hot water as this only gives power when heating demand is off.
Nest wont pay a penny, they send a pro installer out to diagnose and rectify then charge you an obscene amount for your electricians f up, not worth wasting your time over.
Mighty_Genghis
Has thanked: 9 times
Been thanked: 8 times
Post by Mighty_Genghis »
ashc18688 wrote:Wiring diagram from Nest is fine, I've fitted in excess of 400 of these as a nest pro installer. More than likely the electrician has wired it up wrong in the first place and then not checked his wiring, the amount of units I have been out to because of incorrect installation from third parties is crazy.
Thanks ashc, I’m surprised the electrician had got it wrong as he’s massively experienced but perhaps as it’s a new system there’s bits he doesn’t know. It’s all working now so I’m loathe to get it changed so do I need to ? (It is using 1 which you’re saying isn’t needed)
Sent from my iPhone using Tapatalk Pro
