Spot the mistake
- Argyll
- Has thanked: 1183 times
- Been thanked: 581 times
Re: Spot the mistake
Bead is on the outside from what I recall.Gadget wrote:Can't be 100% sure, but I think that one is internally beaded anyway, so was meant to be fitted like that.
- Has thanked: 105 times
- Been thanked: 878 times
its outward opening door the beads look to be on the inside - the hinges maybe the wrong type tho
Our porch door is outward opening as there wasn't enough clearance to have it opening inwards (also gives you move space to move)
- Argyll
Argyll wrote:Surely having the hinges externally must create a security issue?
It should have pins on the hinge side tbh with that amount of glass - that would go in first
- Been thanked: 2 times
Yes the brackets at the top.. how are you going to cover them.. or why are they they[emoji85]
Sent from my SM-G950F using Tapatalk
- Has thanked: 8 times
- Been thanked: 1 time
Presumably because they didn’t want to chop out the plaster board reveals and make more of a mess . Maybe they couldn’t fix through the frame because it landed in the cavity . I thought that about the straps - must be getting rendered .ryanedgar72 wrote:Yes the brackets at the top.. how are you going to cover them.. or why are they they[emoji85]
Maybe those brackets are doing a different job.. because why would you need 4 on top of the frame.. screw fixings on the sides should be enough..D4np wrote:Presumably because they didn’t want to chop out the plaster board reveals and make more of a mess . Maybe they couldn’t fix through the frame because it landed in the cavity . I thought that about the straps - must be getting rendered .ryanedgar72 wrote:Yes the brackets at the top.. how are you going to cover them.. or why are they they[emoji85]
