Forum Down
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Re: Forum Down
Post by thescruff »
I would have thought Root or BillyGoat could throw some light on this as it clearly an inhouse problem with one or all of the 3 racks.
gas4you
Has thanked: 419 times
Been thanked: 900 times
Re: Forum Down
Post by gas4you »
This is the current results from here with everything flying
1,192.168.2.1,2ms,None,----
2,212.74.111.217,29ms,lo99.lon-1-sip.as91,----
3,80.40.119.145,30ms,ge1-0-0-23.lon10.as,----
4,10.72.11.73,45ms,None,----
5,80.40.155.37,30ms,xe-9-3-0.bragg001.l,----
6,80.40.155.62,30ms,xe-7-0-0.scr001.loh,----
7,78.144.0.190,29ms,host-78-144-0-190.a,----
8,195.66.225.138,31ms,linx.redstation.net,----
9,109.200.16.217,36ms,217-16-200-109.rack,----
10,109.200.16.186,36ms,186-16-200-109.rack,----
11,109.200.27.10,35ms,10-27-200-109.rackc,----
Dave
thescruff
Re: Forum Down
Post by thescruff »
Why has Dave got different IP addresses for the Racks, to Wine~o and me.
Could that be why some have the problem when others don't :dunno:
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Re: Forum Down
Post by wine~o »
thescruff wrote:Why has Dave got different IP addresses for the Racks, to Wine~o and me.
Me neither ...Don't even know what a rack is....
thescruff
Re: Forum Down
Post by thescruff »
Rackcentre what UHM connects too.
One of the three was down for nearly an hour, I wondered if one or two went down whether it put load on the remaining servers.
Has thanked: 1012 times
Been thanked: 918 times
Re: Forum Down
Post by ultimatehandyman »
:dunno:
Support are still looking into the issue
thescruff
Re: Forum Down
Post by thescruff »
ultimatehandyman wrote:Support have answered and have done the following-
I have reconfigured the connection limit and settings of apache now to allow for more traffic and better handling and flushed the firewall. I also set a cron to restart apache every 6 hours to keep it refreshed and avoid any build up to cause it to lag.
Hopefully this will eradicate the slow loading page problem
Whatever they did here emulated the fault perfectly.
thescruff
Re: Forum Down
Post by thescruff »
13 109.200.16.206, 206-16-200-109.rackcentre.redstation.net.uk timeout
Timed out for the last 40mins just back.
thescruff
Re: Forum Down
Post by thescruff »
Slowing up a tad.
wine~o
Re: Forum Down
Post by wine~o »
Slowed right down again for a few minutes...
1,192.168.1.1,1ms,None,----
2,----,Timeout,n/a,----
3,78.151.225.209,18ms,host-78-151-225-209,----
4,78.151.225.236,19ms,host-78-151-225-236,----
5,62.24.240.13,20ms,xe-11-2-0-rt001.the,----
6,78.144.1.4,19ms,xe-11-2-0-scr001.th,----
7,78.144.0.160,21ms,host-78-144-0-160.a,----
8,195.66.225.138,20ms,linx.redstation.net,----
9,109.200.16.217,24ms,217-16-200-109.rack,----
10,----,Timeout,n/a,----
11,109.200.27.10,25ms,10-27-200-109.rackc,----
root
Has thanked: 168 times
Been thanked: 173 times
Re: Forum Down
Post by root »
a traceroute will map your particular isp's route to an end point so for different isp's/people the hops will be different depending on how complicated the routing is to the destination. to be honest without gathering data from one source to the destination and then being in the datacentre where i can pinpoint the systems that are routing the traffic into the racks I wouldn't be able to tell you much. Although if you restart apache using a cron job like apachectl | graceful, this will more than likely destroy the session variables on the server causing people to have to re-log in sometimes.
- Dave
root
Re: Forum Down
Post by root »
which ISP's are you guys on?
- Dave
wine~o
Re: Forum Down
Post by wine~o »
Talk talk, though don't think that's the problem as different users using different Isps are having the same problems, though sometimes some are whilst some are not...if that makes sense..
root
Re: Forum Down
Post by root »
yup makes sense, could be loads of things causing it, a load balancer in the datacentre could be out meaning when people are routed through that machine they dont get anywhere.... a dns server somewhere en-route from isp to datacentre could be malfunctioning and taking a long time to resolve the address. :dunno:
- Dave
thescruff
Re: Forum Down
Post by thescruff »
With Virgin.
If it was a datacentre en-route from isp, why would a range of users have the same problem.
Would one rack going down put extra traffic on the other two.
Return to “Computers”
