losgiganteskid wrote:There is no gap surrounding the laminate - it abutts up against the skirting and over the years has not moved a jot due I guess to it having been stuck down with pinkgriplockie wrote:Ask yourself this why is it advised to leave a 10mm gap around the edges when laying laminate ?
The answer it is because it expands and contracts.How can your tiles do the same when it expands and contracts.
It may stick well enough but the grout will open up at it expands, the tiles may even crack too.
in the words of Theo Paphitis " IM OUT" ! its obvious that you know better than the likes of me, (ive only stuck about 4000 metres of tiles down and up over the years) so go ahead stick your tiles to your laminate it will be fine, okey dokey, no problemo!
there you go tou got what you wanted to hear! BYEEEEEEEE
