TYPES OF WELDING HITCH
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
How about this one :laughing3: :laughing3:
low loss header 002.jpg (106.8 KiB) Viewed 3305 times
My van.jpg (74.4 KiB) Viewed 3305 times
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Now thats pipework porn mmmm :jerk:
dave.m
Deceased 07-06-2012 R.I.P
Has thanked: 13 times
Been thanked: 318 times
Post by dave.m »
John,
I always believed you would show some improvement after the safety valve incident.
I had confidence in you.
dave
But you cannot tell him much.
diyguys
Has thanked: 178 times
Been thanked: 19 times
Post by diyguys »
Hay not bad for a begginer :wink: what welding machine did you use or is it gas.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
I think only Indians gas weld now diyguys ;)
100% xray Scruff? :lol:
thescruff
Post by thescruff »
Hitch wrote:I think only Indians gas weld now diyguys ;)
I reckon you could. :thumbright:
Double weld on all the outside joins, and the flanges are also welded on the inside.
Even stitched the inside back edge to stop the 8" pipe bending.
This was arc, but bronze with gas every time :thumbright:
Oh and gas for brazing.
Stoday
Deceased 21-10-2011 R.I.P
Has thanked: 8 times
Been thanked: 90 times
Post by Stoday »
You're missing the point, diyjizz. Most of constructional work has been de-skilled, so a DIYer can easily do it, given time and only a little skill. But some still need real skill that can only be acquired with a lot of effort.
Take plumbing. A centuary ago, plumbers had to plumb lead pipes, make their own tees and elbows in lead; tap and fit MI pipes and create gravity heating systems. Not so any more. Lead pipes were replaced with copper with easily soldered fittings and now with push-fit and so on.
If you want to compare welding with plumbing, then a wiped joint would be the appropriate comparison. That needs skill which takes time to learn. With welding, anyone can lay a track, but it needs skill to get the penetration right.
Hitch
Post by Hitch »
I was always taught you need to learm to grind befor you learn to weld.
Its true, joint prepertion in 50% or it.
:thumbright:
diyguys
Post by diyguys »
Stoday wrote:You're missing the point, diyjizz. Most of constructional work has been de-skilled, so a DIYer can easily do it, given time and only a little skill. But some still need real skill that can only be acquired with a lot of effort.
You havent posted any of your work stojizzer.
thescruff
Post by thescruff »
They didn't have camera's when Studay was working. :lol:
diyguys
Post by diyguys »
I heard he was about the same time as the dinosaurs,some people dont like progress ,must be all that lead he worked with. :lol:
diyguys
Post by diyguys »
:sleepy1: Thanks for the history lesson, thats what it is history, thank god for we have progressed.Years ago people use to hunt with spears and arrows and live in caves lol.
dave.m
Post by dave.m »
diyguys,
Arc Welder £29-99
Welding Electrodes £3-99 per kilo
Available from lidl from Thursday 22nd.
Hitch
Post by Hitch »
80a...youd need to be welding anything over 3mm thick uphand :roll:
dave.m
Post by dave.m »
Hitch,
I know nowt about welding but saw them in the flier that I get and thought it would do for him to practise with, :shock: :shock:
dave :wink:
