Spell checker?
- Gas/Heating Expert
- Has thanked: 24 times
- Been thanked: 294 times
Re: Spell checker?
The quik brow fex jumpod ovr the laxy dof
Well right clicking does bring up the usual Undo, copy, paste, delete but nothing about checking spelling !
Thats with AOL 9.0 browser!
Cutting and pasting in the AOL email writer and spell checking identifies SIX misspellings.
Tony
Tony
- northwales4u
- Has thanked: 76 times
- Been thanked: 151 times
- Contact:
Re: Spell checker?
The context menu that comes up when you right click varies between browser programs (apart from the usual cut, paste etc) so its hit and miss if the spell checker is listed there.
Have you tried looking in the help section of your AOL browser? If there is no drop down Help menu at the top, press F1 to get it and do a search for Spell Check
Mike
- northwales4u
- Contact:
Re: Spell checker?
Had a look in the help section, have you tried this:
To choose your preferences on AOL 9.0:
1. Sign-on to AOL and choose Settings from the AOL toolbar or go to AOL Keyword: Preferences.
2. In the Preferences window that opens, find the the setting you want to change in one of the following ways:
* Click the Essentials tab to see the most frequently-used settings
* Click the By Category tab to browse a full list of settings, grouped into categories (Billing, Communication, Multimedia, etc.)
* Click the A-Z tab to browse a full list of settings, ordered alphabetically
3. When you have found the setting you want to change, simply click its name.
4. Make the necessary adjustments and click Save.
Note: The settings window shows many more options when you are connected to the AOL service. When you're offline, you only see those settings that you can adjust while you're offline. The others require you to sign on to AOL first.
Mike
- northwales4u
- Contact:
Re: Spell checker?
The browser probably doesnt have a spell checker then. Have you tried downloaded another browser (like Firefox) or does AOL go mad if you try it?
Mike
Re: Spell checker?
I have not tried Firefox at home but use it elsewhere sometimes. It is rather tedious compared with the AOL as that has all the email well saved and easy to fine..
I can also use IE but rarely use that either as much communication is with email and thats so much easier to manage with the AOL program.
One annoying aspect is that it does not have an auto forward facility but i have not discovered if I can use that with IE or FF and AOL either.
Tony
Tony
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- thescruff
- Has thanked: 820 times
- Been thanked: 3520 times
Re: Spell checker?
I downloaded the Google Toolbar and it has a spellchecker built in that I use for everything.
- northwales4u
- Contact:
Re: Spell checker?
DWD, I think the Google Toolbar only works with mainstream browsers not sure if it will work with AOL or if AOL will let him download it
Mike
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Re: Spell checker?
Firefox has a built in spell checker that underlines mis-spelt words with a red line.
I'm sure it can be added to the forum, but it would probably have a button that would require pressing to check the spelling before posting.
The limited edit time is not to prevent normal members from eidting their posts to correct spelling etc. It is there to prevent spammers from editing their posts at a later date.
