Bathroom rebuild - Work in progress
davemulheran
Has thanked: 54 times
Been thanked: 23 times
Re: Bathroom rebuild - Work in progress
Post by davemulheran »
moderator6 wrote:It's looking good Dave :salute:
Quick question though are those 4" joists? I thought you weren't allowed to cut notches in them?? :dunno:
Thanks mate
I'm not sure now all the floor is fixed down. I tried to re-use all the notches that were there when I lifted the old floorboards. This was all done prior to me moving in im afraid
moderator6
UHM Super Moderator
Has thanked: 141 times
Been thanked: 362 times
Post by moderator6 »
Ah well it's done now so it'll be fine :wink:
davemulheran
Haha, i hope so!
Just checked as the bottom of the joists past the floor in the bathroom are on show as beams in the room below
there is 3" of beam showing underneath, plus whatever is above, so i'd say at least 6" joists
wine~o
Has thanked: 1414 times
Been thanked: 4015 times
Post by wine~o »
*phew* breathe a sigh of relief...
davemulheran
Well, one wall done .. 4 more to go! I cant believe this took me ALL day!
still need to put some 6mm boards inside the niches and cut the centre
this guy tried to help by chewing everything in sight
This little guy tried to help clean up by chewing everything
These users thanked the author davemulheran for the post:
white pan man
wine~o
Post by wine~o »
another House Rabbit..
mcluma
Has thanked: 5 times
Been thanked: 26 times
Post by mcluma »
Did you not screw the marmox boards on the floor?????
what adhesive for the marmox did you use
prem
Been thanked: 17 times
Post by prem »
is that the stabila laser level you have there, just bought one last mth. are you keeping a eye on the budget, nice to see top end materials being used. they do come at a cost :roll:
davemulheran
mcluma wrote:Did you not screw the marmox boards on the floor?????
Yes I screwed the marmox boards down with plastic washers and stainless screws.
I used marmox sealant in between all the boards too for a waterproof seal. I shall also be tanking with mapegum and taping all the joins before I lay the UFH and the SLC screed over the top
The adhesive was a SPF cementous mix. Mapei Keraflex to be exact.
davemulheran
prem wrote:is that the stabila laser level you have there, just bought one last mth. are you keeping a eye on the budget, nice to see top end materials being used. they do come at a cost :roll:
Hi Prem. Yep its a stabila. Has been a lifesaver whilst tiling my kitchen and putting up the walls in the bathroom. It doesnt do floors though so I have just bought a cheapy Stanley S2 laser floor square.
You are right about quality materials costing. Ive just bought another 5 bags of keraflex ready to use for the floor and walls. 10kg of kerapoxy grout and 3 bags of mapei fibre SLC... not a good day on the wallet!
mcluma
Post by mcluma »
I like the mapei stuff,
And you did good on the floor, in the fist pics i couldn't see the screws with the washers
i do hate the SS screws, they cam out so quickly
davemulheran
mcluma wrote:I like the mapei stuff,
Thank you :)
Yeah the driver slipped a few times!
I ended up using quite short screws that took up the 6mm cement board, a few mill for the adehsive and the 18mm for the ply
that way there was no danger of piercing any pipework
mcluma
Post by mcluma »
Here is my son laying some marmox boards
and then the underfloor heating
davemulheran
another day.. another poxy wall that was as straight as elton john!
some bits arrived today
BLOODY NICHES! laser level is a god send
note the new stud additions, may aswell have built a new frame ! well they do say its all in the prep!
wall done!
VODKA TIME!
white pan man
davemulheran
WELL, today I have been sealing, taping and tanking. Horrible job.. especially when you run out of tape. 30 metres not enough!? So had to run down to Marmox AGAIN!
Tomorrow i'll do the second coat... tell you what.. this mapegum is THICK. doesnt seem to go very far either. NEarly done a 5kg tub for what you can see below.
Ohh I ordered a load of tools/goodies from tradetiler and kwikstick (or something similar) so tiling wont be long!
Im knackered, time for a steak and vodka tonight!
white pan man
Return to “Show Case Gallery”
